mine were maxing before it cut.
so my informeter told me anyway.
so i was forced to baby the car around lol
emanage can clamp the aiflow at 4.6 as mine is.. anything after that is mapped by a boost sensor plugged into the emanage.
Yeah the Informeter suggests I max my injectors out without the suction.; hardly have to baby it - its first/second gear at 5k where I get into the upper region.
But yeah - mapping the extra airflow via boost sensor sounds fine to me. Its just clamping it at 4.6 WITHOUT the emanage that sounds like danger to me
So the suction pipe doesn't max the injectors just the AFM? If that's the case wouldn't a fuel cut defender fix that by clamping at say 4.6V? If the injectors are maxed then obviously needs bigger injectors.
If you're gonna cut fuel what's the point of flowing more air?
Am I missing something here?
I've got the MAP sensor installed but doesn't seem there's a need to use it...>_<
yeh it probably is a bigger danger doing it without bigger injectors.. which cant be done without an EMU
lol fuel cutdefender in this case would be used to clamp the voltage of AFM to 4.6v.. allowing it to rev freely without an air flow cut.
it adds fuel to the map if you have more boost.
ie. cold whether more boost - the map sensor will add fuel to keep it safe. get cihan to set it up
Ironpaw had a tune done before the map sensor was installed, so after 4.6 volts, cihan guessed the mapping, which he is really good at.
when he goes for the next tune, cihan will integrate it with the emanage
Whats wrong with your 3 dials? My boost gauge isn't working, but I found a thread on Scotty's soldering fix, so I'll do that, get it working, then think about changing it :D
mines an RX, only RS had the dials and the relevant sensors/loom etc. so if i cant get it working, ill be selling all the working bits and going a double DIN
the voltage readout works lol and i think if i change the BCM ill get the attesa working too. the boost sensor is missing the plug in the enging bay loom. but i rekon the wiring is there
i think there were tests done and raising the back of the bonnet doesnt really work. bonnet vents are the only real way to get air out :(
did you run a line from the battery directly to the pump? then its 14.4v already :P
Would creating a vent at back of the bonnet by timing the plastic trim on the back of the bonnet?
Cheers
Andy
Depends what else you do while raising it....trimmed some plastic out so it can flow/get dragged out.
I used a 12v relay...so it's 12v at the moment....If I need to step it up I will use the other one I got from Scott.
Did you want a factory boost sensor Iain or did you get one from the wreck?
Well that sounds like verdict is rip it off until I have done injectors, emanage and fuel pump? DAMMIT! And I was so looking forward to dyno day!
Wouldn't have thought a standard car with plenum spacer, exhaust and suction pipe would have maxed out the injectors?
I would leave it on until and see what the tuner can get out of it.....remember he will lean it off....you may get away with it running at about 92% duty cycle on standard boost!
I just spoke to Andrew, he was recommending a tune just with the exhaust. Sounds like I can do it without doing injectors etc, but excuse my ignorance can I get it tuned without going Emanage? I've only ever had one car tuned, and that was the R31 after I did the engine rebuild. Not exactly sophisticated so it was just done at Ultra Tune.
Unfortunately not on the stock ECU. Unless you send it to Japan.. :whistling:
Exhaust, Sierra S1 and stock boost you should get away with no injections with the E-Manage tune....or Exhaust, Suction Pipe, standard turbo and stock boost!....maybe!...anything more and you are pushing the envelope like I did!...not fun!
You will be in the 90% duty cycle mark more than likely.....so make sure your injectors are alway's clean!
Edited by Jetwreck
Yep. No tune for u unless u get an emu installed...or a fcon...
Lol at ultratune 'tuning' cars!!
Edited by ironpaw
Yeah agree, but it was just timing, nothing complex! Thats my excuse and I'm sticking to it!
Off to buy an Emanage then... any suggestions where?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
