mine were maxing before it cut.
so my informeter told me anyway.
so i was forced to baby the car around lol
emanage can clamp the aiflow at 4.6 as mine is.. anything after that is mapped by a boost sensor plugged into the emanage.
Yeah the Informeter suggests I max my injectors out without the suction.; hardly have to baby it - its first/second gear at 5k where I get into the upper region.
But yeah - mapping the extra airflow via boost sensor sounds fine to me. Its just clamping it at 4.6 WITHOUT the emanage that sounds like danger to me
So the suction pipe doesn't max the injectors just the AFM? If that's the case wouldn't a fuel cut defender fix that by clamping at say 4.6V? If the injectors are maxed then obviously needs bigger injectors.
If you're gonna cut fuel what's the point of flowing more air?
Am I missing something here?
I've got the MAP sensor installed but doesn't seem there's a need to use it...>_<
yeh it probably is a bigger danger doing it without bigger injectors.. which cant be done without an EMU
lol fuel cutdefender in this case would be used to clamp the voltage of AFM to 4.6v.. allowing it to rev freely without an air flow cut.
it adds fuel to the map if you have more boost.
ie. cold whether more boost - the map sensor will add fuel to keep it safe. get cihan to set it up
Ironpaw had a tune done before the map sensor was installed, so after 4.6 volts, cihan guessed the mapping, which he is really good at.
when he goes for the next tune, cihan will integrate it with the emanage
Whats wrong with your 3 dials? My boost gauge isn't working, but I found a thread on Scotty's soldering fix, so I'll do that, get it working, then think about changing it :D
mines an RX, only RS had the dials and the relevant sensors/loom etc. so if i cant get it working, ill be selling all the working bits and going a double DIN
the voltage readout works lol and i think if i change the BCM ill get the attesa working too. the boost sensor is missing the plug in the enging bay loom. but i rekon the wiring is there
i think there were tests done and raising the back of the bonnet doesnt really work. bonnet vents are the only real way to get air out :(
did you run a line from the battery directly to the pump? then its 14.4v already :P
Would creating a vent at back of the bonnet by timing the plastic trim on the back of the bonnet?
Cheers
Andy
Depends what else you do while raising it....trimmed some plastic out so it can flow/get dragged out.
I used a 12v relay...so it's 12v at the moment....If I need to step it up I will use the other one I got from Scott.
Did you want a factory boost sensor Iain or did you get one from the wreck?
Well that sounds like verdict is rip it off until I have done injectors, emanage and fuel pump? DAMMIT! And I was so looking forward to dyno day!
Wouldn't have thought a standard car with plenum spacer, exhaust and suction pipe would have maxed out the injectors?
I would leave it on until and see what the tuner can get out of it.....remember he will lean it off....you may get away with it running at about 92% duty cycle on standard boost!
I just spoke to Andrew, he was recommending a tune just with the exhaust. Sounds like I can do it without doing injectors etc, but excuse my ignorance can I get it tuned without going Emanage? I've only ever had one car tuned, and that was the R31 after I did the engine rebuild. Not exactly sophisticated so it was just done at Ultra Tune.
Unfortunately not on the stock ECU. Unless you send it to Japan.. :whistling:
Exhaust, Sierra S1 and stock boost you should get away with no injections with the E-Manage tune....or Exhaust, Suction Pipe, standard turbo and stock boost!....maybe!...anything more and you are pushing the envelope like I did!...not fun!
You will be in the 90% duty cycle mark more than likely.....so make sure your injectors are alway's clean!
Edited by Jetwreck
Yep. No tune for u unless u get an emu installed...or a fcon...
Lol at ultratune 'tuning' cars!!
Edited by ironpaw
Yeah agree, but it was just timing, nothing complex! Thats my excuse and I'm sticking to it!
Off to buy an Emanage then... any suggestions where?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
