mine were maxing before it cut.
so my informeter told me anyway.
so i was forced to baby the car around lol
emanage can clamp the aiflow at 4.6 as mine is.. anything after that is mapped by a boost sensor plugged into the emanage.
Yeah the Informeter suggests I max my injectors out without the suction.; hardly have to baby it - its first/second gear at 5k where I get into the upper region.
But yeah - mapping the extra airflow via boost sensor sounds fine to me. Its just clamping it at 4.6 WITHOUT the emanage that sounds like danger to me
So the suction pipe doesn't max the injectors just the AFM? If that's the case wouldn't a fuel cut defender fix that by clamping at say 4.6V? If the injectors are maxed then obviously needs bigger injectors.
If you're gonna cut fuel what's the point of flowing more air?
Am I missing something here?
I've got the MAP sensor installed but doesn't seem there's a need to use it...>_<
yeh it probably is a bigger danger doing it without bigger injectors.. which cant be done without an EMU
lol fuel cutdefender in this case would be used to clamp the voltage of AFM to 4.6v.. allowing it to rev freely without an air flow cut.
it adds fuel to the map if you have more boost.
ie. cold whether more boost - the map sensor will add fuel to keep it safe. get cihan to set it up
Ironpaw had a tune done before the map sensor was installed, so after 4.6 volts, cihan guessed the mapping, which he is really good at.
when he goes for the next tune, cihan will integrate it with the emanage
Whats wrong with your 3 dials? My boost gauge isn't working, but I found a thread on Scotty's soldering fix, so I'll do that, get it working, then think about changing it :D
mines an RX, only RS had the dials and the relevant sensors/loom etc. so if i cant get it working, ill be selling all the working bits and going a double DIN
the voltage readout works lol and i think if i change the BCM ill get the attesa working too. the boost sensor is missing the plug in the enging bay loom. but i rekon the wiring is there
i think there were tests done and raising the back of the bonnet doesnt really work. bonnet vents are the only real way to get air out :(
did you run a line from the battery directly to the pump? then its 14.4v already :P
Would creating a vent at back of the bonnet by timing the plastic trim on the back of the bonnet?
Cheers
Andy
Depends what else you do while raising it....trimmed some plastic out so it can flow/get dragged out.
I used a 12v relay...so it's 12v at the moment....If I need to step it up I will use the other one I got from Scott.
Did you want a factory boost sensor Iain or did you get one from the wreck?
Well that sounds like verdict is rip it off until I have done injectors, emanage and fuel pump? DAMMIT! And I was so looking forward to dyno day!
Wouldn't have thought a standard car with plenum spacer, exhaust and suction pipe would have maxed out the injectors?
I would leave it on until and see what the tuner can get out of it.....remember he will lean it off....you may get away with it running at about 92% duty cycle on standard boost!
I just spoke to Andrew, he was recommending a tune just with the exhaust. Sounds like I can do it without doing injectors etc, but excuse my ignorance can I get it tuned without going Emanage? I've only ever had one car tuned, and that was the R31 after I did the engine rebuild. Not exactly sophisticated so it was just done at Ultra Tune.
Unfortunately not on the stock ECU. Unless you send it to Japan.. :whistling:
Exhaust, Sierra S1 and stock boost you should get away with no injections with the E-Manage tune....or Exhaust, Suction Pipe, standard turbo and stock boost!....maybe!...anything more and you are pushing the envelope like I did!...not fun!
You will be in the 90% duty cycle mark more than likely.....so make sure your injectors are alway's clean!
Edited by Jetwreck
Yep. No tune for u unless u get an emu installed...or a fcon...
Lol at ultratune 'tuning' cars!!
Edited by ironpaw
Yeah agree, but it was just timing, nothing complex! Thats my excuse and I'm sticking to it!
Off to buy an Emanage then... any suggestions where?
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
