Gave the car some love today and did an oil change with Sugi 6000 (last bottle I had :( ) .
Will need to do a brake service very soon and get the rotors machined.
My safety inspection found my regular problem of a snapped rear swaybar Mount... :(
Time for Dales super duper ones. and might as well go for the heavy duty links as well.
Sorted mate, see you tonight.
If anyone else wants a set?:whistling:
On another note; a new shipment of Stagea bars arriving soon, so if you missed out last time; now's your chance.:thumbsup:
I can also get C34 bars if anyone wishes... PM for a price.
do I care.......what else can she take off me!!!
hate to say it, but make sure the Grp A r32 is "owned" by someone else in your family (ie dad) other than yourself.
been through all this, does NOT end pretty.
lol at this
A guy at work had one of those black ford coupes ( mad Max car, one of 20 black ones ) sold for less then $20k in his divorce. :O. Normal sale price closer to $100k in the same condition.
No probs with that...it is dads!....only when he meets with an accident will it be mine!
good work!!
now thats a problem that scared the sh1t out of me when it happened lol
I was unfortunately able to recognize/diagnose it within a second when it died this time >_< But the upside was that I wasn't concerned about a) not being unable to get it home or b) it being a costly fix.
Ok it's about time I put something in here that actuallly relates to the thread title
I've fitted a hypergear atr43ss-1, braided water lines, twin 3inch drift pipes, and searched all over my drivetrain looking for a loose bolt that would make my car vibrate constantly and surge at low speeds.
good, I was sure that was the case.
Ive been through what you are currently going thru, albeit mine was different in the sense that once I was put onto disability her true colours came out, refused to work, came into mortgage stress, relationship breakdown, ends with seperation. Actually pretty much started the downward spiral after the birth of our second child - ex had post natal depression & wouldnt do anything about it.. in the end anything she said was a) full of swear words to both me and the children, b) yelled everything at top of lungs. Got impossible to talk to her about anything without her going OFF her tree.
If she cant pull her butt plug out soon, then I suggest you both get some counselling if you both want to continue the relationship. Lest face it, sex is a form of communication. In my instance Ive ended up having to sell my house and giving her most the money left over after costs/owings, seeing the kids are with her for two thirds a week. She never put a cent into the house/fees/etc but being the mum gets to walk away with 50% more than myself.
On topic, my Stagea is with Boostworx being pulled down. Depending on the condition of cylinder#5 it'll be 86mm CP pistons, hopefully an overbore isnt needed.
water cooled? i dont think thats what it is
i know the block youre talking about. just steal one from an old oil filter :P
no i dont think you do..
theres a water line that goes into the oil plate.
i pulled it apart on scottys spar motor yesterday to have a look. it looks like a silicone orange crush gasket seal of some sort.
unless thats what your talking about?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
