Yeah cheers guys, I know about the chasis rail idea and I'm staying clear of it. In my trade I've seen tons of jobs stuffed up due to people using incorrect tools or methods.
I've heard of a way you can get access to the ring gear to stop the engine turning over, I'll slide under tomorrow and have a look. My other option is I have access to an impact bar, sort of like a breaker bar but you hit the end of it with a hammer, should get in there easy with that. I dont really want to have to go pick it up so I'll look into ring gear access first lol.
A manual is so much easier. Put it in gear and foot on brake. Damn auto!
mate i am with you dont risk it do it with the punch bar put it on the bolt hit with hammer done safe. You could also if you have the standard radator take it out have it core flushed cost me cheap while out do the timing belt makes it so much easier.
Yeah done, went and got my 1/2" impact bar from work today and had it off in no time. I had the coolant system flushed out about a year ago so I'm not to worried about it. I wasn't keen on removing the radiator because I didn't want to deal with the auto fluid lines going into it.
I managed to lift the radiator up enough to see if the rattle gun would fit. No good, the AC coil is still in the way.
Got my alarm fitted on the weekend, picked it up Monday. Took longer than expected, but it's working now, ah well.
Surprised to find the mirror covers with LED indicators were scotch locked in. Got disturbed during install and disconnected my LH indicators >_< Installer found it though so it's all good.
I'm thinking the best way to do alarms and immobilisers in these things is to replace all the scotch locks and dodgy wiring on the factory unit then install an aftermarket Australian standard one. This is how GT Autosound do it and this way you get to keep cool stuff like your mirrors dipping and folding in, and the interior light turning on when you unlock the car.
Pretty happy with the end result though, even if it is a bit more simple.
My Freeway Dolphin strut brace has arrived at work, but I'm holed up at home for a couple of days. Might have to swing past and pick it up tomorrow, then work out if I have room for a plenum spacer and the strut brace, or choose between the two.
Next mod almost definitely a set of BCs. Can't stand the ride as it is now. Rotors, intercooler and spot lights are also high on the priority list.
Nah Craig told me to ditch it ages ago, as it traps too much heat apparently.
I'll let everyone know once it's on. I'm hoping room for the plenum spacer and strut brace. Fingers crossed!
I don't care about the engine cover...just wanna know if I can run the brace....
Oh and the dents I mentioned in an earlier post:
Do you think I should get it fixed before going to get a retune this Sat, or is not much of an issue?
no it will be installed in my new engine. i pretty sure with the spacer on, you cant have the engine cover AND the strut brace. but 19mm shouldnt foul the brace i rekon
i think its time for scott to make a custom one lol
OUCH!! i think youll be ok mate, go for the tune
Ok so I fitted the strut brace, and because Im a clumsy dick I made it take much longer than it needed too, as i kept dropping the 12 mm nuts from the strut tops...
So Ive lost one nut... Would I be right to drive it for a day while I get a replacement?
Or is there a less important 12mm nut somewhere on the car I can steal temporarily?
Only can find 14mm nut. Not sure how many they have. If it has 3 and your missing one it will be fine but if it only has 2 and missing one I would carefully head straight to Japanese import spares and grab the correct 12mm nut from a skyline.
Edited by slippylotion
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
