LOL took a month for him to start work on it?
I take it he's doing this for free :whistling:
Contemplating getting the Nismo front bar...hmmm
Hmmm, they were refurbished and in primer WEEKS ago; but when he gets busy...
The Nismo bar is porn; if I could've found one, that's what I'd have.
your wifes gonna chop your balls off.
No BC's Ryan?
Yup, BCs. Looked at heaps of others but everyone is so happy with their BCs why bother? Seem like the most practical, and one of the cheapest, options.
Looks like I'm getting a set of DBA 4000 disks too, hopefully find out tomorrow :ph34r:
Ok so I've done something. Took the airbox out last night and now my Atessa light is showing on the dashboard. I believe there is a relay right near the airbox, which makes too much sense to not be the problem, but everything looks plugged in and ok.
Is there a common problem with this thing?
And it's the relay UNDER the airbox for the 4WD, not the ones next to it, isn't it Brad :whistling:
Something for the "What haven't you done to your Stagea" pile, I haven't ordered my BCs because Just Jap haven't got any stock. 7 day wait at this stage, which almost makes it worth going to Street to Track.
Brain fail. I think it's the check engine light that is showing up. Two years of no cars and longer with no Nissans. :laugh:
Only other thing is plug in the boost controller/turbo timer harness in last night. Can of worms opened!
Edited by jasevr4
Did you unplug the OEM boost solenoid?
Id say check the error codes, theres a squence to get the CEL to flash which corrospondes to OBD2 error code list. The squence is documented here: http://www.m35stagea...ic.php?f=6&t=11 and the error codes: http://www.m35stagea...ic.php?f=6&t=12
Checked the codes. Realised how much I blink usually hah.
Pretty sure it was P0100 Mass or Volume Air Flow Circuit Malfunction or P0110 Intake Air Temperature Sensor.
Either way, cleared the codes and it's fine now. I'm wondering if I clicked my car onto ON without the AFM plugged in or something..
:rofl: I have the same issue.
That'd definitely cause the CEL light to stay on for a while, it would eventually turn itself off apparently, but when I've had it happen to me I've always just cleared it.
If that was the cause, it shouldnt come back on now. Easy fix :thumbsup:
yeah turning the car on without starting it WILL throw a CEL if the AFM isnt plugged in.
and dunc is right, it will clear itself after a few days, but you can clear it if you want yourself......
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
