So... Anyone got an xtrail or dualis?
Yeah, I've got an X-Trail, though it's a 2003 STR model if that makes a difference. What do you need?
I thought Bbenny had the best fitment, and spoolin. PN-mad looks like he has similar fitment now, so just go with that. :thumbsup:
Looks tough imho!
I believe Spoolin is 9.5 x 19" +22 offset now. Reckoned they needed a roll on the rears; nothing on the front.
Photos look EPIC!:worship:
Makes for one seriously angry Stag! :thumbsup:
Awesome! Are the rear license plate lights the same as the Stag? Or at least the same size?
The lights themselves, or the holders that the lights go in? The lights are just little spade LEDs, I replaced mine on sunday!
I think he was meaning the whole fitting. Possibly something to do with a reverse cam.
Sorry to say, in my case no. The Stag housing has 100mm screw spacing with a flat plastic cover. My X-Trail has screw spacings of 55mm with an old fashioned bulbous looking cover hidden under the tailgate handle.
Mine is an early model though. I think the more current ones could be the same. Can you drop by a Nissan place to have a look?
Spot on, looking at a wireless reverse cam that replaces one of the light holders: http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=130432830364&ssPageName=STRK:MEWAX:IT
You might be right. I'll drop past Main North Nissan and check the new ones. That would make sense if it was for X-Trail and Dualis, maybe that's the newer model X-Trail.
I'll check it out and let you know.
Spot on, looking at a wireless reverse cam that replaces one of the light holders: http://cgi.ebay.com....e=STRK:MEWAX:IT
Talk about going the extra mile, lol. I spotted a new X-Trail just now and measured the light surround. It is about 70mm long & about the same width as ours, maybe a little narrower. So although it isn't quite the same size, you may be able to make up something to hold it in there, since it is pretty well hidden on our cars anyway. I'm thinking thin aluminium sheet with cut out for new light/camera gizmo & holes to screw it into the Stag mount points for original light.
Cheers mate.:thumbsup:
Nah, not fussed TBH.:nyaanyaa: Maybe a set of PM skirts. Maybe.
One day...
also needs more low :P
lol nah kidding, looks good mate! im guessing with those wheels you CAN get big brakes under them?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
