depends on how much??
fixed the knock in the rear suspension, turns out the locking ring hadnt been done up and the strut was slowly unscrewing itself. problem solved! also reset the rear height, gave the springs some preload, so much better now. gotta do the fronts next.
i think the front knock is actually a groan and its the new poly bushes are not greased up enough :(
Good that you found the problem!:thumbsup:
How did you preload the rear springs Iain?
My understanding is that you can only preload if the damper is topped out (at full extension). In our case all you'd be doing is increasing your ride height.
Preloading springs is more of a motorbike thing due to the fact that at rest, with no rider (on a sports bike at least) the suspension is basically at the top of it's stroke (topped out), whereas in a car the suspension sits down an inch or more (at least) when at rest.
well, there is a height adjustment on the strut, so i measured the length of the thread to the ring 'flange'. this pulled the entire wheel assembly up as its shortened the length of the strut. then i screwed the 'height' adjustment of the spring land till it was captive (originally they werent) and then a little more. i measured both sides and they are even now.
the front i didnt touch as i couldnt move one of the rings for the spring land. ill attack it later and preload a little more.
dont wanna be a pain, but do you reckon you could take pictures?
Did the brake wire mod and installed a switch in the top of my glovebox. I did this not because I stall it up and launch it all the time, but because I live in the hills and drive on windy roads every day. Was quite skeptical about how much difference it would make as my car only has an exhaust, but went for a drive last night and was extremely suprised at the difference out of corners :rofl2: . Thanks to all that put the effort in to working the mod out :thumbsup: .
Edited by MOUTH
glad your happy with it. who needs the nismo ecu now :nyaanyaa:
because the stock ECU doesnt advance the cams like the nismo :P
Do the Mines/Impul/Gzone remaps play with the cams? I'd assume they do, but from memory the associated websites for them are all extremely vauge on what they actually 'do' :closedeyes:
lol low end cams? i dont know if Im wrong but I think scotts vmanage showed that the cams are retard down low.
of what part?
and no, not till next weekend lol
whenever your free to do it man, a write up how to stiffen pre load would be good.
Ok, I get you; I already run my shocks as short as they can go to minimise the amount of "droop" available as the shock extends.
Thing is, on mine, at the height I run, the spring is barely captive. Increasing the "preload" wouldn't make a difference on mine. Perhaps my springs are slightly shorter than yours?
thats entirely possibly about the spring length. but i think they are all the same.
the back is now firm, it was a little sloppy before. looking at it when i got home, i think it can go down maybe 1cm further at the rear. the boot was full of my tools so i couldnt throw it around too much.
the front will need to come down, or maybe just preload the springs more
Don't you want some droop? It forces the wheels to maintain contact with the road when you go over a bump. Having too much droop is bad as this will force the car to raise when cornering too much (dependant on spring rates/shock rates etc.)
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
