Rewired towbar plug so that I have no external socket for my trailer; so much neater.
Used flat cable so I can just put it out through the tailgate when I need it, and chuck it in the wheel well when not in use.
A bit boring, but still...
Might fit the new plastic mesh insert in my front bar tomorrow if I don't go riding.
Edited by Daleo
Humour me - by removing the factory radiator (losing the transmission cooler), and then installing a 11"x7-1/2"x3/4" transmission cooler, along with about 800mm of extra hose total, surely the system would need more fluid?
At the moment the dipstick doesn't show any dark fluid on it, which is exactly what is draining from the trans cooler hoses, but appears to have a heap of fluid on it - up to the little s bend in the dipstick.
Is this a problem with topping up from the dipstick?
I've read on the G35 forums that the dipstick is pretty hard to read, but if anyone has any advice I'd like to hear it.
My advice is the dipsticks on our cars are shit.
How much fluid did you put in? Probably only talking about 0.5-1L difference.
Where are you filling it from?
so epic fail with the 'wire cut' mod. must have cut the wrong wire. when i flicked the switch, it dropped a cylinder lol
anyway, installed a western digital live media player in the car. works fine, mounted up front in one of those waste-of-space pocket things. cut out a hole (nice and bodgey) and mounted it in there.
im getting a bit of noise in the picture so ill have to use a sheilded co-ax cable to the back of the car.
anyway, installed a western digital live media player in the car. works fine, mounted up front in one of those waste-of-uuspace pocket things. cut out a hole (nice and bodgey) and mounted it in there.
Lol at cutting the wrong wire...
Are u running the stock firmware on the wdtv? Can it act as a DLNA server?
i upgraded the firmware last week when i got it. yes its WD firmware
i have a DLNA server already, but it will read the files off it. as for it BEING the server, no idea sorry.
I must admit; it took me a while to drag it out of the middle of the harness, they don't want you going after it... Maybe you can market your mod as "Active Cylinder Deactivation" just like a VE Crumblydore...
Don't let it deter you; go again!
I thought the " Awesome" didn't need the snippage anyway?
the awesome becomes more awesomerer with the wire snip :)
i have a factory size toggle switch to go into the 3 spots down on the right, they are all full on my car, so is the 4th one below :(
I used a Stainless steel switch from Jaycar; http://www.jaycar.co...&SUBCATID=978#1
Flush mount, you could put one of these anywhere as they are really low profile. I used one of the factory spots (cos I have no options :whistling: )
I was considering putting the switch on the parking brake but the switch I had wouldn't have worked. Plastic version of what Daleo posted
My plan was to put the switch on the actual pedal so when you pushed it down you would be pushing on the switch.
I ended up putting the switch in the compartment above the glove box
a toggle switch would be better IMO, that way you can leave it in normal mode for when the wifey/dodgey mate drives it.
plus then you dont have to press the brake while holding the button in :P
BTW, because that ECU input is a simple 12V, if you don't want to throw a switch (or push a button) AND press the brake pedal every now and then to keep the MIL light off, you could wire the switch with 12V to the ECU (ie. not from your brake pedal)
Yeah, I know, by the time you flick the switch / press the button you might as well press the brake as well....lol
Edited by Commsman
Well I got my braided lines and wireless reverse camera in the mail yesterday, just waiting on the rear rotors and suspension now.
Not sure if I'm even getting my suspension now. If I don't hear from Street to Track by tomorrow I'll be reporting to the bank to get my money back. Service is terrible, and still waiting for my shocks 3 weeks later. Now they guy won't even respond to emails. Major disappointment.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
