More work done by Craig this arvo.
The lower front control arms (or are they ball joints???) were replaced due some very worn rubber. Endless clunking on every road,
probably would on glass if I could try some.
Exchanged them for some new ones with purple natholane or urethane rubber. Can't remember the name of the product.
The car has been transformed yet again. Just like a new one, even better. :banana:
Craig has a great setup with the workshop, so as Molly Meldrum used to say....
"Do ya selves a favour and check it out!!!"
Needless to say, this is a very good replacement and the workshop setup is excellent.
I might just get him to do all the work on my car :worship:
Rear rotors turned up today, another set of DBA 4000 Clubspec T3s :banana:
Now have everything for the brake upgrade, just waiting till the shocks turn up. Which I'm still waiting for.
Wish I'd done a bit more research before I ordered. If I'd known then what I know now, I never would have ordered from STT. It's $100 saving, and it's a total joke. Not worth it. :spank:
Just made up a cool air box as the rb26 runs a bit hot and under the bonnett is pretty high temperatures
It is fed through the vent on the nismo front - I made a sealed ducting in glass fibre and enlarged the size of the hole up to the filter area.
Fabricated a barrier out of carbon sheet so that the pipes and filters go through and are sealed with heat reflective gold on the engine side
I have never liked the sealed top so spent a fair amount of time cutting the top to the profile of the bonnett and then used a door seal which slips nicely over the cardon and seals to the bonnett "carpet"
BTW the washer bottle was replaced by a tank that also is an alloy catchtank.
That is now where the battery was which has relocated to inside the rear wing - fits a treat
Edited by RSVFOURUK
I'm sure they will come - sucks to hear about everything that has happened but I don't think the guy is a scammer.
Picked up Slippy's r33 gtst brake kit last night. Not sure when they will go on.
Yeah got the tracking number this morning. I don't think the guy is a scammer either, but he is an absolute joke. I can't recommend highly enough that people stay away.
There goes your fuel economy Iain! Is the AFM the same as the PNM35?
lol just a short drive to the city this morning and i used a lot of fuel
nah its the same as a t30 xtrail - 22680-6N211
thats for the hotwire only, not the whole tube - which isnt required anyway
You might want to post that in the info thread or on the Awesome forum, with a key word to make it easy to find.:thumbsup:
Cost of the Entrail AFM?
ill be doing that mate, also with a diasnosis and what to do when it happens to you in the middle of the bush in coffs harbour on a dirt track :P
Crank it till it starts, put put along at 2200rpm till you make it back to home? :P First time I killed my AFM I'd been on some dusty roads not too long prior to it letting go also incidentally.
the mechanic suggested i put some vaso around the airfilter to stop dust getting around the rubber seal as its not 100% sealed.
when i opened the airbox yesterday, there was dust inside, after the filter.
so when going on dusty roads, do that i rekon!
is this FYI enough for everyone??
http://www.m35stagea.info/forum/viewtopic.php?f=6&t=258
dont joke about that! i think i set the record for longest journey without an AFM on an AFM equipped car lol
No doubt, you obliterated my 100km trek back home! Still dont know how you managed that!
550km+
the nissan dealers said the part was overnight from sydney, so i decided i was heading there anyway.
you will probably find it was "the exact" part that they were going to ship to Coff's as what you have in your car atm......$350 shipping...LOL!
Has anyone on here done a track day in their M35?
I know Craig has, but I'm doing one in November and I'm trying to work out if I need to fit an oil and trans cooler beforehand. I know it's a good idea to have them anyway, but I need to work out if I have to or not.
Anyone run round a track without these coolers?
Give me a call....I'll talk you through it ryan.
There is a few things that I did to ensure nothing broke or cooked.
Edited by Jetwreck
Had an alarm fitted to the M35 today by John at Marveytech. Great price and quality work as usual.
If your in Adelaide and need an alarm fitted to your M35, go see him as you won't be dissapointed.
Edited by slippylotion
Sittin here watching "Late show with Craig Ferguson" thought I'd share
Bought a couple of Drift seats a while back, recently bought some universal seat rails off RoadsterGarage. Thanks Adam.
I'm in the process of fitting the passenger side, with custom mounts. Slow process cause of my accident but I'm enjoying the whole process of finding what works and what doesnt.
Below is one of the seats.
first attempt at mounting brackets.......Too high (FAIL)
Left rear mounting bracket (I know my welding is shyte, but thats what happens when the power keeps tripping out) :angry:
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
