Got me one of these....... :yes: Aha yes I did
Will be a while till its on, as I'm waiting till I see my knee specialist at the end of the month. My last visit was..........lets just say less than encouraging.
Still, I'm soooo happy I bought it. :woot: :woot: :woot:
Nice.....I like it!
Detailed mine, and put it under a car cover again (sigh... I wish I had a garage: that way I could actually SEE the car when its not in use!). Pretty sure I'll be whipping the covers off again soon: the weather's starting to get nice and chilly again!
Had my AFM die on me. Boosting up a hill the power just cut out completely, it would barely idle and wouldnt rev. Fortunately i managed to limp the car home by disconnecting the AFM.
Fearing an expensive replacement was on the cards i soaked the AFM with some contact cleaner, let it sit over night and then tired it out in the morning. Amazingly the engine started up great, idled perfect and drove fantastic. In fact its driving better then ever, i went on a 100km drive this arvo with a whole bunch of blasts of the throttle. Fuel consumption is better and revving feels a lot smoother.
I'd recommend giving your AFM a clean even if its functioning well. Next weekend i'll try cleaning the wife's V35 AFM which is working fine to see if it shows an improvement
Serviced the car last night, oil (trying ULX110), filter, replaced belts, air filter and spark plugs (NGK)...... My car had a slight miss under big load and my economy was pretty average (6/7km per litre) One of my coils was covered in oil (the side that I had my rocker cover gasket changed under warranty) .......needless to say I was pretty impressed. Also I had 3 different kinds of plugs in the car NGK Denso and some wierd jap one WTF, all finger tight (washers on bottom of plugs werent even crushed) :unsure:
Wat? Your kidding, dealer serviced?
Thats a job I would be doing myself, so you can check the plug tubes are clear of oil. They wouldn't even tell you by the sounds of it...
I service my car but haven't done the plugs until now.....I am a qualified mechanic, but when the car was in warranty period (3 months) I got rocker cover/ srs light/ swaybar links/ disc machine blaa blaa done, As I figure I am paying all this money, I am not working on my daily when I don't have to.....
Also when I got it onto the hoist i have noticed I have a couple of very bald (camber) rear tyres and most of my bushes in the front need replacing, so at last I have a reason for changing wheels and tyres instead of the chrome gayness. Will also be needing bushes ASAP
Now just talking to the guys that did the warranty work. They did the outer rocker seal and the inner isn't serviceable (around the spark plug tubes) and you need to buy a new rocker cover or sealant the shiz out of it and cross your fingers? I take it they warp?, anyone had this problem before? Someone has had a go at the sealant already (as one of coils also had sealant on it).....
I did it but I wouldn't recommend using too much sealant in there, probably best to find another rocker cover, new if possible, but they were over $200 I seem to remember and would have to come from Japan. The plug tube seal isn't replaceable.
Awesome.......I wouldn't bother with a second hand rocker as mostly likely would have/will warp.....I am getting a few quotes on rockers covers now..... but this is money I would rather be spending on suspension or exhaust or on my race car......
Will report back with quotes
Edited by MOUTH
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
