I don't know if your mate is my mate (Chris from Craved Coatings), but he did the radiator, oil cooler and sump on my race car, it definately ran a degree or 2 cooler afterwards. When you are pushing everything super hard, every degree makes a difference.
Duncan, my mate is in Penrith also; but it's not Chris. I've seen the Powdercoating that Chris does & his work is amazing, my mate is only just getting in to the decorative coatings, and there's a few ceramics (the polished finish ones) he does that Chris can't do.
You're dead right though; at the limit, every little bit makes a difference, and there al all kinds of coatings, heat shedding, heat retention, heat reflecting, anti scuff, lubricant holding, lubricant shedding; the list goes on and on.
I'm really going to have to investigate these coatings more because I drive my nimble beast at the limit every time I take it out.
LOL.
The creaking and clunking tune it makes now is horrible. Seems everything is coming at once ATM. Attesa pump, cam cover seal and piano bushes. That's three so hopefully good for a bit now ?
Edited by slippylotion
Update; Turbo is out now. :banana:
post-61153-0-47778500-1343300106_thumb.jpg post-61153-0-45897300-1343300163_thumb.jpg
Truly there has never been a better example of the right tools for the job than this job.
After wasting hours yesterday with the heatshield bolts; we bought two Snap On spanners and a 3/8 drive 10mm single hex socket. What couldn't be achieved in several hours; removing the heatshield was completed in around 20 minutes. This cleared the way to finally free the turbo from its home.
I've also modified the offending heatshield so that the remaining section can be refitted; all the bolts can now be accessed, and it can be completely removed in about 2 mins.
In other news, the exhaust housing, dump and mid pipe have now been blasted, baked, blasted again, and coated in the thermal basecoat.
It has now been baked out and is cooling. The external thermal coating will be going on tomorrow, with the internal coating for the exhaust housing and dump to follow.
post-61153-0-82551900-1343300963_thumb.jpgpost-61153-0-60004400-1343300888_thumb.jpgpost-61153-0-53352900-1343300874_thumb.jpg
The coating goes on a greeny colour as seen on the Dump & Mid pipe; then dries almost white, as seen on the exhaust housing.
Once baked; they are almost completely white.
Edited by Daleo
I can get some numbers for you tomorrow; they're about $55 each though. I'm planning to marry mine.
I didn't take a pic of the heatshield, but I'll get one tomorrow.
Sweet, thanks. Should start getting the tool kit in order for when the inevitable happens.
What is the gap like on the rear wheel from the housing? It looks to have huge clearance, is it just the photo?
That's only a baby turbine, should be responsive. Good choice buddy. :)
My special tools... Cost : $0 ;)
The clearance is reasonably tight; I think it's just the pic, there's a couple of funny reflections & shadows. The coating will close the clearance down slightly too.
I'm hoping so; we'll see in a few days.
Trust me; if the Snap On truck hadn't been in the corner, we'd have been doing the same. I already had one long spanner made up.
Paul, I took some measurements today, but I left everything at the workshop.
I forgot to mention, I received these springs in the mail today, should hold the gate shut till around 26 - 30 psi. :)
Install tomorrow along with the thermo fan controller.
Anyone for a 3.5 inch dump?
And the new torque converter, packing triple Pathfinder lockup clutches. Not sure when I will get time to drop the gearbox again...
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
