Cost me bout $4500 when i did mine, gt3582r precision 48mm gate custom stainless steam pipe manifold kando braided lines & 3 1/2 inch dump to cat
thats about what i have been quoted
i can still dirve it as it just floged out the berring and it some times even makes boost.But i think i gave it its r.i.p today when a ve 6ltr was up my ass so i gave it a squart left him for dead then poof little cloud of blue smoke and no more boost :whistling:
Im only on a light tune with stock injectors and making 270kw on 14 psi. Prob not a good idea to drive with a shagged turbo bearing, comp wheel could rub on housing and get fillings in the engine!
That's what I thought but I was assured it would be ok
Are they prepared to cover the costs of any damage to the engine from this advice?
The turbine wheel on disintegration has been known to revert thru the exhaust valves and cause scoring of bores on 26's.
What goes wrong with -9's or -7's or -5's??
I didn't say anything in particular would go wrong with any particular type of turbo, just that there is less to go wrong cause there is one as opposed to two!
Have a look in the f/s forum on here, so easy to find bolt on upgrades for gtrs
You'd probably come in under $2k for some new twins, injectors and a tune
Under 2 grand?
I need you to do some shopping for me.
Under 2 grand?
Lol yeh just one 2871 is about 1500 new I dont know how your getting two(or similar) for under that let alone with injectors and a tune. Shiiieet
Awesome; I'll join the queue for $1000 programmable ECU/tune packages! :banana:
On my NM35 it's errr;
Expensive? :yucky:
we're talking 260rs's here
so i assumed he had a tuneable ecu already seeing as he made 270kw already
m35 owners need moar manual, then it may get easier
No doubt, I'm just having a little sook.
This M35 owner would just like moar moneyz... :(
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
