Cost me bout $4500 when i did mine, gt3582r precision 48mm gate custom stainless steam pipe manifold kando braided lines & 3 1/2 inch dump to cat
thats about what i have been quoted
i can still dirve it as it just floged out the berring and it some times even makes boost.But i think i gave it its r.i.p today when a ve 6ltr was up my ass so i gave it a squart left him for dead then poof little cloud of blue smoke and no more boost :whistling:
Im only on a light tune with stock injectors and making 270kw on 14 psi. Prob not a good idea to drive with a shagged turbo bearing, comp wheel could rub on housing and get fillings in the engine!
That's what I thought but I was assured it would be ok
Are they prepared to cover the costs of any damage to the engine from this advice?
The turbine wheel on disintegration has been known to revert thru the exhaust valves and cause scoring of bores on 26's.
What goes wrong with -9's or -7's or -5's??
I didn't say anything in particular would go wrong with any particular type of turbo, just that there is less to go wrong cause there is one as opposed to two!
Have a look in the f/s forum on here, so easy to find bolt on upgrades for gtrs
You'd probably come in under $2k for some new twins, injectors and a tune
Under 2 grand?
I need you to do some shopping for me.
Under 2 grand?
Lol yeh just one 2871 is about 1500 new I dont know how your getting two(or similar) for under that let alone with injectors and a tune. Shiiieet
Awesome; I'll join the queue for $1000 programmable ECU/tune packages! :banana:
On my NM35 it's errr;
Expensive? :yucky:
we're talking 260rs's here
so i assumed he had a tuneable ecu already seeing as he made 270kw already
m35 owners need moar manual, then it may get easier
No doubt, I'm just having a little sook.
This M35 owner would just like moar moneyz... :(
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
