m35 owners need moar manual, then it may get easier
Meh, aint going to happen any time soon unless you want rwd skids, there is nothing wrong with the auto anyway. Why do you want easy? I like the challenge.
When the m35 ecu is 20 years old and has years of motorsport development behind it we may have more aftermarket ecu options. Until then, what's wrong with the Fcon Vpro?
You like the challenge because no more aus post lol. Lucky f**k
D'oh! Blocked Cat on the dyno, and boost actuators are too small! Cat was causing 8psi backpressure, apparently.
So.... New HKS actuators being fitted first thing tomorrow, cat to be freed up, and back we go to the dyno... Can't help but shudder when I try to calculate what the bill is going to be this time around: one thing has necessitated another, which has necessitated another etc etc you get the picture... :(
Well it looks like I wont be taking the Stagea to SuperFap. Couldn't get Tie Rod ends for it in time. No one in NSW/QLD had factory or aftermarket stock. Have 2 on order from Nissan Aus, but wont arrive until tomorrow.
Gotta take the wife's car instead.
we're talking 260rs's here
so i assumed he had a tuneable ecu already seeing as he made 270kw already
yep i have a nistune
You wanna talk bills get a 260rs
i just did a full rebuild,bought some second hand gtss and one has now let go :wacko: now im doing what i should of done the first place :domokun: a singel turbo conversion that bill is $5,000.All this after just buying my first unit im sure up s@#%t creek without a paddle :whistling:
Edited by R33huntme
Finally, the pics of my suction pipe.
Firstly, excuse the first pic; this is not the usual standard of my welding. Issues with the TIG at my mates workshop, resulted in oxidised weld beads, and I ended up having to MIG the Blow Off return into position. Internally the pipe was purged, so it's immaculate.
Pics of the pipe after coating; the ugly welds are not visible; but I still know they're there...
post-61153-0-67699200-1344431863_thumb.jpgpost-61153-0-80967900-1344431892_thumb.jpgpost-61153-0-54284600-1344431925_thumb.jpg
The two pipes side by side; doesn't really give much of an idea how much larger internally, and better flowing the new one is; because externally, they're almost the same size.
And in it's new home; possibly never to be seen again...
No comparison times as yet, but I'm very pleased with the end result, and it sounds great coming on boost now.
Nice Dale :thumbsup:
I see you didn't manage to extend the top bolt thru so it can be done up from the front, like the oem intake. I doubt it is possible actually, because of the larger pipe. But it's such a hassle getting onto that bolt..
Edited by Commsman
Looks good Dale, any idea what the ceramic coat would cost?
Cheers mate, I can find out & get back to you.
I didn't, because I ended up just using a socket headed M8 bolt. The way I oriented the pipe; it's possible, and fairly easy to locate & tighten the bolt with a ball end allen key. I just hook a small spanner over the short end of the allen key to tighten it at the end.
I had the pipe on & off several times (was a bit tired & forgot to reconnect the water lines) and it's pretty easy to access, but if I was to make another, I'd index the bend a little lower to give a bit straighter shot at the bolt.
i just did a full rebuild,bought some second hand gtss and one has now let go :wacko: now im doing what i should of done the first place :domokun: a singel turbo conversion that bill is $5,000.All this after Ijust buying my first unit im sure up s@#%t creek without a paddle :whistling:
I hear you: Mine's a conversion from RSfour. I know the wallet pain of an RB26 all too well...
That said, it's been worth every cent so far!
Looking at picking it up on the weekend hopefully.
Last tune before these shenannigans was 420hp @wheels. First time with all the new gear was 409hp but with less boost due to the enormous back pressure. Hopefully I'll gain a little top end, but I'm hoping for much earlier spool and a dirty bug chunk of midrange torque this time around.
Fingers crossed... ;)
Awesome work Dale.
Is that 2.5" pipe?
Now I know whats holding up the front braces! :P
Yeah, 2.5" mandrel bends. Much smoother inside than the factory piece.
Lol, a bit; it was mostly having no car and having to ride everywhere that's been the biggest delay.
They'll be going out early next week.
No worries, all good!
Is everyone making them out of 2.5"? Might make it easier with mine, just have to change the bottom half (perhaps even from your new production run? :whistling: ) and I can keep my 2.5" -> 3" second half...
The bottom one is the hard one imo.
The bottom one is the easiest for me. My top bolt needs a ground down spanner & each time I get 1/8th of a turn, plus I rip my forearm up as I jam it down in there.
Now that sounds cleverer than my standard hex head bolt. I may look into a better method, but each time I put it back I tell myself not to bother since that will be the last time I need to remove/replace it. Must have doen it more than 10 times so far & it needs to come off one more time (redo turbo oil line). But this will be the last time, lol.
2.5 inch should be good to around 240-250kw, for anything more 3 inch would be required imo.
And that should suit 90% of people on here. Production run....?
Edited by Commsman
Hey Leon, I have some good news regarding your oil leak mate; check PM's :D
I'm a little reluctant, as I will not take money out of Scotty's pocket on this one. If Scotty is ok with it; I may look at it.
The other issue is as Scotty has said; this one will not support maximum power, and you'll need to start again if you want to shoot higher than the 240odd kW mark.
good luck let us know what you end up getting
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
