Australian Tax Office?
The only people that can help would be Fair Trading...
yep, you would be surprised when you there's dodgy dwellings going even if there's not , just mention the ato and Wamo:)
Fitted the temp controller I bought from Scotty this arvo; after a bit of rewiring, I now have fan control.
Also threw my rear brace on ; but haven't driven far enough to feel the difference yet.
So it all works fine? Good to hear Dale. :)
I should fit mine...
Sure does mate, but not before I'd given it a good stern swearing at.
The good news is; the thermocouple appears pretty accurate.
I wanted to test it on it's lowest setting (70deg) and it still hadn't cut in at 85 deg; so I thought something was amiss.
Swore for a bit, then switched it off & had another go; the important bit was setting the dip switch to allow the dips to adjust; not the button.
Due to the clear, concise directions; I'm not sure how I missed that bit. :rolleyes:
Going to run it with the thermocouple on the rad and see how it performs; I may end up moving elsewhere.
Stagea is going on the hoist tomorrow (thanks to Andrew at ASR Automotive in Castle Hill for making some room for me to enjoy my day off) for a wheel rotation, plugs, oil + filter, fuel filter and drop the front driveshaft. Meanwhile the ECU is coming out while the Nistune is reflashed with a manual image...thanks to the original supplier I have an auto image and it is anyone's guess whether that has been causing some issues with boost cut, throttle recovery, cold/hot start and few other niggles??
Then Saturday up to DVS-JEZ's dyno for a bit of a check of the tune. While up there I will try a different CAS, drop exhaust and play around with a few settings.
I had a little care package arrive yesterday from Iamhe77. 3" Nismo exhaust and Ox rear brace.. Will admit I am pretty happy so far. The car is a little quieter then i expected but i think once i change my dump and front pipe it should be just about perfect.
The OX bar seems to have made a little difference, Cant wait for the front now
My Legalis was pretty quite until I finished it off with a dump and de-cat front pipe :)
All went smoothly enough car has new fluids, plugs etc ready for some dyno time on Saturday.
Big thanks to MRC for removing the Nistune and flashing the manual image back onto the board. Mark was kind enough to show me the full procedure from de-soldering and bridging the board to put the board into the correct mode to reprogram and then the reverse.
Glad you're happy Josh but I should mention again that 70mm is 2 3/4", not 3".
Missing my rear brace :( Guess I need to find somewhere down here that could make up a custom brace...
Just back from DVS-JEZ after tidying up the tune with the manual image. Great job by Jez sorting out all of the issues with the fat slug.
The drivability off the line is so much better with a few changes to the variable cam timing and a few tweaks with fuel and timing just off idle. Found a some more power by going a richer in the midrange to top end. It liked the extra cooling and made some solid power gains with a few more degrees timing.
More low? Maybe grab a set of Silk Roads?
SO....Scotty helped me fitted the SilkRoads Coilovers today...with the custom springs from SilkRoads (Previous ones were too low)
REsult: Now I can go bush bashing...fronts look good but rears are now ARX height, if not higher :S
Edited by ironpaw
So 80's hotrod spec with the arse in the air? Picsbeforeanglegrinder
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
