task's this weekend to complete on the RS260, engine damperner kit, change oil again, change diff oil, put head unit in and sort rear lcd screens. source the push clutch fork setup to convert my pull system, and work more on my hidden shift light in standard dash cluster!
Task's on vl, removed manifolds from 26/30, put them on the 26, sort out the sump so i can get the 26 back in the vl and tuned finally
task's this weekend to complete on the RS260, engine damperner kit, change oil again, change diff oil, put head unit in and sort rear lcd screens. source the push clutch fork setup to convert my pull system, and work more on my hidden shift light in standard dash cluster! Task's on vl, removed manifolds from 26/30, put them on the 26, sort out the sump so i can get the 26 back in the vl and tuned finally
can u please let me know what u find on the pull to push clutch setup as I would like to change mine to :)
You haven't got much planned; why not pick up your act a bit? :woot:
