Nah plenum isn't painted, just gave it a hit with a scale remover and autosol haha..
Bov pipe is a 3" straight alloy, I picked up a couple of nipples and gave to the welder with the original pipe so he could re create the same angles etc came out really good imo.
However i do get a bit of flutter at lower boost with the kompact if I drop the throttle.. Anyone tried softer springs with success?
  • Like 1
Softer springs will help with the flutter, but it will open more at idle and cruise with vac behind it. If the flutter isn't bad just leave it, otherwise ring Turbosmart and get them to ship you the next softest spring.
Mine doesn't flutter at all, on the evo or the Stagea.
Plus your on over 30psi :D bet it's pretty quick
Actually makes more noise the less boost I spool the turbo to. Still almost silent using the stock airbox though, in both cars.
Yeah man, I'm after one, was wondering where he got it from. I reckon they are a nice subtle touch, you think so?
Yep I love it, my car has one. He cpuld be like me and had it come from factory like it
Hey mate, this was a random score. I joined a Facebook group "stagea owners club" it's NZ based.
One of the lads on their was selling his car which has the spoiler and kindly offered it for swaps with an original and cash his way. I went straight to the ATM lol.
I know lots of people after them and for some reason they are dam hard to get. Good luck on finding one.
As for the wheels they are wolf s36 18x8.5 and 9.5 245/45/18s offset I'm a little unsure measures roughly 20/30p. Lowered on bc golds no rubbing etc
Damn, I'll have to keep looking. I was hoping it may have been a site online, I don't really want to see if I can get one from Nissan direct ($$$$$$$$$$). I may see if I can find that group, being in NZ myself
Also, that plenum looks good, a flapper disc and autosol you say? hmmm.
Replaced cam cover gaskets today, new plugs plfr6's, new oil and filter ( royal 5w 30) and gave it a good degrease/ clean. Chuck the boost T in tomorrow and see if this turbos gonna handle 1bar haha.
Talk about carbon build up huh?! Too scared to lift the cam caps :s
Looks nice Nathan; did you have the lines made specially?
Just one thing; I have always oriented fittings toward the top of coolers, gravity takes care of bleeding all the air out of the core.
  • Like 2
what neutral smilie? smile.gif <- that one?[/quote:da693d5855]
nah, you have to click on the 'View more Emoticons' link
it's this one--> :|
everytime i used this--> :mrgreen: i never saw that neautral one, untill tonight
Did you just buy a kit or buy separate parts? Does the sandwich plate have a thermostat in it?
Nice install Nathan but cooler needs ideally to have fittings to top or will work with fittings to side but upside down can result in airlock which means that some or much of the cooler is not working.
Thanks Dale and KiwiRS4T.
Dale yeah I got the lines made up at Pritek.
Brick I bought all the parts separately and yeah the sandwich plate is a Mocal thermostatic one.
Didn't even think about an airlock issue I'll have a look how much play I have with the lines to try mount on top of the Reo bar. The lines are quite stiff though as they are steel braided inside and fittings are fixed in there orientation. Having to buy new lines to run in a different mounting spot will suck but I'll take a shit at it.
  • Like 1
I was just thinking back where I saw the mounting orientation with fittings facing downwards and remembered it was on the mishimoto 350z install they did. So mounting the cooler with the fittings downwards is guaranteeing an airlock??
Hi Zach,
That's "interesting"...running different width wheels...have you had any issues with respect to the Attessa?
Hi Zach,
I'm running 9.5 fronts and 10 rears for over 2 years now with no Atessa issues.
I could barely notice any vibration caused by my mismatched rims using the same tyres. There was a slight vibration under acceleration though, only when the transfer case kicked in hard.
The more power you run, the more torque gets transferred, meaning more pressure goes to the clutch pack in the transfer case. This is likely to cause vibration as there is no slip on the clutches to accommodate the mismatched tyre sizes.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
