So there was a write up to the changes to the stagea model and the reasons behind why they relocated the springs the way they have.
It went something along the lines that the ability to separate springs to the shocks was to allow the cargo compartment not to be hindered by higher strut towers and the ability to displace the load under stress. I may be wrong in my understanding but would it also mean the design of a shock and spring system wouldn't allow enough rebound or loading of the compartment?
When I bought my MCA I thought (incorrectly) that all M35 coilover kits converted the rear to a proper coilover and also that MCA is a well know/respected brand that make quality products and wouldn't sell something dangerous and/or of inferior quality. Along with reaperblitz I thought the change in suspension was to make room for larger compartment not due to load sharing, after all OEM springs are generally quite a lot larger in diameter than aftermarket coilovers hence would require a large shock tower which would take space away from the rear compartment.
Been trying to find all these failed shock mounts on MCA equiped M35's. No luck yet. I did find this though: http://www.sau.com.au/forums/topic/440310-coilover-issue/Both ARX, one with stock suspension, one with aftermarket, both look like the bolts pulled out rather than a problem with compression forces. One due to incorrect adjustment of the shock and one due to loose mounting nuts by the sound of it. You can also see the damper adjuster in one pic exposed to the elements and covered in road grime. If you pull away the interior trim you will see a very strong, reinforced, well engineered C pillar which by chance is what the shock mount forces are applied to. I'll go with an expert, say like someone who builds suspension for a living rather than speculation of what might happen. I'm sure Mr Nissan knew what he was doing but if they got it right from the factory then why would we bother modifying our cars at all. On another note you can specify what springs you want at no extra cost with MCA and don't have to change the large spring again which is a PITA. If you are happy with your BCs, awesome but don't bash the MCAs just because you reckon.
Not bashing at all; there's no question about Josh's product, nor his knowledge.
However; regardless of how well reinforced you might think the shock mount is; I don't believe it was ever designed to support the entire corner of the car on that tiny little sheetmetal cup bolted to the bodywork.
Not speculation; fact.
"I don't believe" = fact? Interesting.
Show me the evidence.
A shock mount is not designed to hold weight its sole purpose is to control the spring. The spring on the other hand does hold the weight of the corner of car
I think i quoted wrong person anyhoo
Edited by stripey
Yeah, semantics; wrote it in a hurry, and thought about it later.
Still not fit for purpose; otherwise Nissan would've just put the whole lot there.
Every strut top I've ever seen or worked with has a hell of a lot more surface area to distribute the load; this arrangement does nothing of the sort. Instead, it localises the entire corner weight of the vehicle on a tiny unsupported piece of sheetmetal spotwelded over a void in the body.
There is absolutely no benefit or performance advantage in combining the spring and shock into one position in this instance; and avoiding using the specifically designed and reinforced spring perch is just an exercise in simplifying his parts bin because he now doesn't need to have custom wound mini-block springs as per OEM.
He can just use his off the shelf small diameter coilover spec springs to maximise his profit.
I stand by my comment, but you are free to do whatever you choose.
Just out of clarity (until I can find the actual reason/ information) m35 rwd is different suspension than the m35 4wd yes?
But the chassis is pretty much the same minus the subframe?
M35 shares its front suspension with the Z33 and V35; the rear suspension and subframe is identical between NM35 and M35
http://www.nissan-global.com/EN/NEWS/2001/_STORY/011016-01.html
Suspension: Featuring a new multi-link rear suspension designed specifically for wagon application
The new Stagea employs four wheel multi-link suspension and realizes superior handling, stability and ride comfort.
Its rear suspension is a newly developed multi-link rear suspension that has the coil springs mounted separately from the shock absorbers and lowers the upper attachment position of the shock absorbers by 270 mm compared with the suspension on the previous model. As a result, this dedicated wagon suspension minimizes intrusions into the luggage area.
Ripple-control shock absorbers are used to isolate the transmission of minute vibrations from the road surface for improved tire-road contact.
*Still can't find the type of multi link system explanation
http://nissan.epcdata.ru/stagea/nm35/6839-vq25det/trans/431/
Edited by Reaperblitz
Thanks for clearing that up Daleo. Slightly off topic. Why would they sell different kits to cater for the 4wd compared to the rwd? Added weight of attEsa system?
they sell different kit as the front suspension is slightly different in the front ie the way the coil over is mounted and its style as it has the front drive shafts in the way of where the lower mounts are
Fair enough. Only time will tell. Just trying to support local and hoping that people don't confuse opinion with fact when deciding on their purchase. All good.
  • Like 1
I've only heard fantastic things about his product; everyone raves about them, and also Josh's product support and knowledge. I have absolutely no axe to grind with MCA at all.
That's why I'm completely mystified by the choice to mount them this way.
TBH; I hope they never have any kind of failure, no customer deserves that, and Josh certainly doesn't either.
This is more than just here mate. This was all mentioned to josh on facebook with concerns and links to the fail as he was developing. Not taking away what he offers what so ever as his profuct has been proven in time attack for years. Im this application this is a big weak point unless the m35 owner sends his/her car to an engineer to strengthen the area in question. 99% of owners wont as this cost plus suspension cost will outweigh other products on the market. And this is not from someone against his product as numerous times i have said i will be keen on MCA blues once i wait to see if current owners running MCAs have this mount cracking/failing in which it eventually will as it has happrned running the BC coilovers set up.
Agree. The shock mount is not designed to take the full weight of the rear.
Different car and setup; In my trucking days there were plenty of people using coilovers on the standard Shock mounts in conjunction with 4 links. Some swore it was fine, but seeing a few fail showed me otherwise.
G35 and 350z with purdy adjustable arms and a Datto 1600 all deleting the factory spring to run a true coilover and they all run more of a shock tower rather than having the mount incorporated into the base of the c pillar. Just sayin'. I wish I had found these damper adjuster extensions (so you don't need to remove the trim) earlier in my research so I could have got away with a smaller access hole in the already weak, flimsy mount. :P
post-135423-0-58039900-1454538431_thumb.jpgpost-135423-0-59756200-1454538450_thumb.jpgpost-135423-0-41492600-1454538471_thumb.jpgpost-135423-0-51704400-1454538833_thumb.jpg
Just looked at the difference. The spring sits on the platform that attaches to the rear end of the brake hub. The modified version uses an adjustable brace? Wouldn't that need to be certified as you're changing the design engineering of the suspension? I.e there's no downward support for where it used to sit?
Just curious- Please entertain the thought process in this
Gives more accurate toe adjustment rather than slotting the subframe.
Thought this was pretty cool if you want to keep the separate spring and shock.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
