Hey guys, i'm looking into finally doing some work on my 34, only thing is there is so many people at different workshops telling me to do different things so i thought i would ask all you good folk that have already gone through this.
This is the short list i have decided on so far (feel free to ask and give advise about any of this as i want to get it right the first time)
Engine
Plazmaman FMIC with piping
Plazmaman plenum and throttle body
Garret GT3076R
Electronics
Link G4
G4 Boost Control
Exhaust
6Boost Manifold
(currently have Blitz 3" cat back)
Any comments or questions about anything would be highly appreciated
Also suggestions for dump/front pipes that will fit this combination would be great to hear
thanks.
Jamie Curran
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/
Im guessing this is what you have said to the people from different workshops and this is why you have got different advice on a large scale...
Don't talk to everybody from different workshops. This will eliminate a lot of your problem. Find reputable workshops and speak to the owners/tuners.
You have not given any detail to what you want from the car at all so nobody can really comment.
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608451
as stated by blu33 not everyone knows what they are talking about, some just think sucker!!!!!!!!!!! and take money, most of your list seeems fine but would leave standard intake and get better injectors instead, the standard plenum in good for way over 400rwhp and gives much better mid range respones, nissan do a lot of rnd to there intake design for a reason, i only say this cause i have a lot more than your doing to your car and went with the greddy intake so on and so forth and watched others make similar power with better mid response with standard intake. but must say gt3076r is a great choice, go the 0.82 rear will see you to 400rwhp but really close to that turbos limit on that rear housing side but thats plenty of power for street. not saying greedy or plazma are crap just not required till round 500rwhp flow mark. oh and go 6 boost manifolds!
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608502
hey guys thanks for the replies,
@bluey33
your right i didn't mention what i was looking for, im going for around the 300rwkw mark. how do i edit this into the original post?
the reason for the different workshops is i moved to qld from vic so had to change, and the first place i went to in qld ripped me off.
The main thing i really want to get a handle on is what is compatible with what, as in what front/dump is compatible with the GT3076R etc.
@17psi r33
yes i have ran into a workshop that has thought just along those lines and got rid of them quite quickly, and thanks for the 0.82 rear tip.
as for the intake manifold i understand what you are saying, i guess a big factor was how much better forward facing plenums look lol. (not afraid to admit it)
Edited by jamie curran
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608524
If you can afford all that good gear then it will certainly save you doing things twice. You will need injectors as well as or instead of FF plenum, and a new, better fuel pump, and better brakes and suspension. An adjustable exhaust cam gear might help you to get to the 300kw that the Gt3076 is capable of but you will also need a GOOD tuner.
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608609
Nothing wrong with that list. You won't really find anything off the shelf for a dump pipe... an exhaust shop or workshop can make something up for you. Add a wastegate, fuel pump maybe some injectors yada yada yada, double what you think its going to cost and your there.
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608622
I'd be doing things the logical route first like fuel pump then injectors and computer . With a bit of a clean up I think you can get close to your target with the std exhaust manifold which will save you heaps .
I would spend the money on head work and the 25/26 are a bit short changed in exhaust valve size . From memory Ferea (Sp ?) and Manley make suitable over sized exhaust valves that go straight in with re cut and opened up std seats at least in an R33 25 head and surely there must be something available for 26 and Neo heads . A tad higher CR by skimming and mild cams would pay off too . Depending on what your valve springs are like they can be shimmed up or replaced with aftermarket ones . Just don't forget that boost pressure is also acting on the back of closed inlet valves and this pressure is working against the inlet valve springs .
The thing I see people reporting is that "hey I only got 280 or 290" but at the end of the day will the last 10 to 20 really matter ? Its just a number and IMO getting to the actual 300 costs appreciably more and it often just means more burnt rubber - and significantly more money .
A good mechanic , technician really , has been telling me for a lot of years the value of the word "adequate" . Its great because it isn't a number but when the result is adequate you go away happy .
I reckon many/most can scare themselves and get real out of shape with a lot less than 280-300 Kw particularly if the engine is responsive and a bit of a torque animal . I think the secret is a good head with good , often OE manifolds , and an adequate turbocharger . The computer and fuel systems have to keep up or you will damage things .
Your call but in my book mods have to have good bang for buck or you spend a lot more and often its for zip .
For example a good std fuel reg is fine if the pump and injectors are up to the task . If the cams are accurately ground to be timed right I'd use std pulleys .
If your coils are in good nick keep them .
Your call .
Edited by discopotato03
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608769
Actually I forgot to add that those Link G4's can use multiple load sensing devices such as TPS and manifold pressure or TPS and mass air flow . I think what some tuners do is make a TPS strategy with either a manifold pressure or mass airflow correction table . I think Scott from Insight , Sydney's ViPec dealer , did tell me that in theory TPS and MAF should be the most accurate overall if tuned properly but some don't like air flow meters .
A .
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608775
have a look in there http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
drop 3076 into the search box on the top right.
3076 kit http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=538&category_id=56&option=com_virtuemart&Itemid=53
you will also need
- justjap front pipe www.justjap.com.au
- highflow cat / no cat
- z32 afm
- pfc / nistune / g4
- ebc (apexi / blitz / hks / g4)
- 550cc+ injectors
- solid intake pipe (you will need this as the standard item sucks closed)
- intercooler (how much is the plazman? jjr turn flow in black looks stock, no holes, retains standard piping, do it all in your garage.)
- bosch or walbro pump
that will burn through $6k. change up the plenum and manifold later on.
But what I would do is the following for 250rwkw
- hypergear highflow on the stock turbo $1000
- jjr front / dump $100
- jjr highflow cat $100
- boost 't $80
- nistune $1000
- s15 injectors / 740cc highflow stockies $450
- bosch pump $150
- jjr black turn flow $550
- solid intake pipe $250
there is ~$3500
in any case, buy the parts yourself then take them to a workshop to get fitted if you dont want to do them yourself.
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608861
you cant use sidefeeds... its a neo.
my set up works phernominally well. its the following.
-siemens deka 60lb injectors
-nistune
-z32
-poncams
-3076 with tial 44mm ex gate
-am performance steampipe manifold
-fmic
-3 inch exhaust
makes 350ish rwkw running an ethanol mix.. but was about 290 rwkw running bp98 and stock cams and smaller gate.
you dont need aftermarket manifolds... 3076 will fit on stock manifold but use an adaptor/spacer that has ex gate port in it also so you can run one. stock intake manifold flows really well.
deka injectors are cheap as.. $400 for a full set brand new.
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608874
hey guys, thanks for all the replies.
one thing i think i need to let you guys know is ill be getting everything together before starting any work, ill be out of country for around 8 months and ill be coming back with a fair bit of cash that ill be using a bite of on the car.
this is the reason i'm trying to find out all the parts that are compatible so i can make sure everything matches up properly.
@KiwiRS4T
hey mate this list is purely power enhancing mods, i already have better suspension, and brakes are on the list.
@aleks
thanks for the dump pipe info, already got onto someone in townsville that will do it but really expensive...
@discopotato03
hey mate thanks for the massive reply, taking everything in and adjusting as you advise.
and i agree with making 300rwkw im not really bothered if i quite make it or not, as i said "around" 300rwkw also it is a weekend car only.
as for the machining side of it, i have a builder that does all the machining and building but doesn't do any tuning, and i am 120% confident with this builder. also do head porting and everything
i am taking in all the parts you guys have suggested and adding them to the list and asking questions, here is how it stands;
Engine
Oversized Exhaust Valves
Valve Springs
Adjustable Cam Gears (is +/- 10 deg from standard good?)
Inlet + Exhaust Cam (
Injectors (11mm?)
Bosch 044
Garret GT3076R
Electronics
Link G4
G4 Boost Control
Exhaust
6Boost Manifold
High Flow Cat (magnaflow?)
Apexi Front Pipe (i can just get the guy at the shop to match the dump pipe up to the front pipe right?)
Custom Dump Pipe from Stainless Customs Townsville (if anyone has a place they would like to suggest please do as townsville is mighty expensive)
HEY SSXRICHO AND SIMON-R32, SEEN UR POST AFTER I POSTED THIS ILL WRITE ANOTHER REPLY
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608897
you need 14mm injectors.. get deka's that suit FG's (they are 3/4 length and drop straight in. i have the full length items and even they work but you need to space the rail by 12mm.
use tomei poncamsm drop in and forget about cam gears.
any reason you want to use the G4? the nistune works well and is cheaper. but you would need boost control of somekind then.
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608902
@ssxRicho
hey mate thanks heaps for that 250rwkw right up, if i end up going for that kinda power.......and its only that much, i could do it now... so thanks heaps for that ill keep it in mind.
@Simon-R32
Thanks for puting up ur build, ive seen ur car as i used to live in vic and go to winton all the time and still visit from time to time, im going to look into changing everything i have now to around what u have, do u mind? lol
Yer i just got talked into the G4 thats all, im happy to change as its gonna cost me alot more for G4, plus i already have a boost T
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608936
@Simon-R32
Are these the 3/4 length injectors?
http://cgi.ebay.com....a#ht_1165wt_905
Also Bids going for some here
http://cgi.ebay.com.au/XR6-Turbo-injectors-siemens-deka-60lb-/160525385156?pt=AU_Car_Parts_Accessories&hash=item25600efdc4#ht_500wt_1156
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608947
ok mate cheers ill keep looking around for 3/4 length if not ill go with them
would i just need the tial 44mm ext gate with 1bar spring?
also ive been meaning to ask how much is would cost me to get an AM Performance heat shield for my 3076R
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5608972
hey simon i take it you are using the NIStune Type 2 board is that correct? The R33 Computer? as i cannot find any for R34 or RB25DET Neo
ALSO i found the injectors u were talking about for $500
http://cgi.ebay.com....m#ht_2289wt_905
is it worth the extra $150?
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5609289
prob not worth it no.
neo nistune is type 4 board http://www.nistune.c...ducts-type4.php
lol didnt even see that, thanks haha
so did u just make up the spacers?
https://www.sau.com.au/forums/topic/348974-rb25-neo-build/#findComment-5609392
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
