After that i installed the hks oil cooler kit, pretty straight foward. With the aircon removed, i decided to
mount it in front of the radiator for now. Gives me more space to utlize my brake ducts.
You might get lucky, but I found my oil temps weren't well controlled with the cooler mounted between intercooler and radiator. It's been moved and hangs underneath the RHS headlight. Time will tell if it works better there.
Went and bought some dry ice today, then went too work removing the sound deadening.
Worked a treat, got all of it out apart from some bits on the tranny tunnel and the vertical
pieces at the rear. I'll get to them with a heat gun a bit later on.
Also removed the aircon box above the passenger side dash, and the fan box on the left side of that. Bloody big items,
not light aswell. I'll remove the whole heater box behind the dash later on, once i take the dash off.
Got a hill climb this weekend so dont want to be rushing to put the car back together.
Another goodie arrived yesterday, a very snug Racetech seat :)
Put the car back together for the huntley hill climb this weekend. Haven't bought a trailer yet so i'll be driving it down there,
hopefully no dramas.
Got some photo's of my new daily and tow bitch.
An 06 Jeep Grand Cherokee Limited, fully optioned, awesome interior, 5.7 Hemi v8. A bit thirsty
but i don't drive that much. In love with it already, tow capacity 3500kg's.
Now i need to get that trailer
put the car back together yesterday and took her out to the Huntley hillclimb this morning.
Went alright, had to get use to the sticky rubber. First time i've used r spec tyres, and
they are alot gripper than the shit i have used before.
The car was missing anyware above 4500-5000, i did have them gapped at 1.1 and they were fine before,
but the combination of removing the cat and putting a larger exhaust plus a couple extra psi was blowing them
out. I'll replace them this week and run them at .8
Was lot of good fun though!
Now to pull the car back apart again :)
  • 2 months later...
nah decided to go a different route with the engine. Going to put all the bolt ons and tune it on e85, but i'll go an rb30 bottom end when it's time.
Was away for a couple months for work, just got back and going to start work on it again fitting the intake manifold, turbo kit and fuel system.
Hopefully get out for a few track days asap. Bought a Tilta trailer so keen to test it out :)
  • 1 month later...
well been away for work non stop which doesnt help, but got a couple days off so trying to get as much done as possible.
Got my head back from the machine shop. Head it cleaned up, oil returns drilled out, valve seat job, supertech springs, retainers, seals, seats.
The hks cams are in, hks manifold is on with a tial wasgegate and the greddy inlet manifold is on. Just waiting on a tomei headgasket to arrive.
Painted the cam covers blue with some left over paint.
Today i fitted a rear oil feed restrictor, blocked off the middle oil feed and fitted some arp head studs to the block.
Also fitted a surge tank with an 044 and wired that up with a relay straight of the battery.
Put the powerfc in and put the blitz dscb spec r in but havent wired it up yet.
Once the headgasket gets in, i'll fit the head, wack on the 3076 and take it in to get tuned on e85.
The car is also on stands as i just sold the te37sl's, and am getting some AME tracers and hankook z221's
THEN........i put oil back in, put coolant in......AND.........coolant started pissing out. Right away, before i even got a chance to try and start the thing.
Had as best a look as i could and there is a full on stream pissing out from the rear welsh plug.
So I am really depressed at the moment, whole week of work for nothing, and as i start work again next week i wont have any time to rip EVERYTHING off again, so probably going to go drop it in to someone.....arghhhhhh
yeah that's a bitch!
i'd be interested to know what valve seats you put in and what valve spring seat pressure your running.
wing and canards look phat, when you re-registered the car as a 2 seater, i assume you had to produce a roadworthy? how ever did you manage to get that wing passed?
i have an rb25 block if your still going that way.
also, doing an rb30 bottom end for the first time so would be happy to collaborate with others who will actually do one and use it on the track.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
