Hey guys,
Well, I've decided that this year I'm going to stop 'talking' about doing something to my R33 and actually 'do' something to it... So first is first, the engine. I've been told, but I'm not 100% positive that it would work...
The plan so far is...
40 thou oversized pistons
'H' Beam rods
R33 RB26 crankshaft
JUN oil pump
New Water pump
Bigger oil sump
Garrett GT35/40
Front-Facing plenium
Bigger throttle body
Headwork to suit with decent size cams.
That's the basics so far... I've been told and read that this plan should work, however I've also been told and read online that the RB26 crank doesn't fit. Any help would be awesome. I'm not after Horsepower Hero status, I just want a gutsy road car I can have fun on the track with.
Thanks.
https://www.sau.com.au/forums/topic/349279-rb25-build/
what about just do the turbo, ECU, injectors, fuel pump, wait for the engine to break and then rebuild???
I wouldnt worry about using a 26 crank, if your not after horsepower hero status...
Why do you want a bigger throttle body?
bigger oil sump, do you have an oil cooler as yet?
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5611980
Hey guys,
'H' Beam rods
R33 RB26 crankshaft
JUN oil pump - Check out the Nitto Oil Pump, cheaper and flows the same or better then the Jun, and it's Australian.
New Water pump
Bigger oil sump
Garrett GT35/40
Thanks.
Yes it does fit, I am going down the same path later this year. I have a R34 GTR crank, and I need to buy RB26 pistons (going 20 thou, 86.5mm) and some forged con rods. The RB25 and RB26 blocks are very similar, the major difference is the stroke of the RB26 over the RB25.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612038
At the moment the only things the ol'girl has is a 3 inch exhaust from the cat-back, boost 'T', coilovers and mags... I only put the coilovers and mags on it. I'm buying a seperate engine and everything I need in the next few months. I just want a safe-going, gutsy engine.
Thanks for the information, Aberax. Is there anything specific I need to do to make it all work out, crank wise?
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612187
Only important if you need them - plenty have not required them for over 350rwkw.
Rob - what is the budget/plan/use of the car etc?
A 3540 isn't the best choice for a street car in all honesty, no do you need to spend the extra on rods etc.
The parts list is a bit all over the place. Lots of stuff you need isn't on there, lots of stuff you don't need is...
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612214
2.6 and 2.5 blocks are the same . thats why rb25det blocks have 2 oil feed lugs cast into them
rb26 has longer stroke and lower piston crown height
so if your using a 26 crank you need pistons for a 26
con rods are same dimesion
  • Like 1
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612218
The plan is to have a nice cruiser that I can go to the track and thrash around without worrying a lot about something major to go faulty. That's why I want to strengthen as much as I can. I plan on working the heads and having stronger valves and springs too. 35/40 just seemed to be a good choice for the track/strip but I'm open for suggestions.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612403
Rob, Check these links out
SAU Topic - Garrett GTX Turbos
Garrett Website - GTX3076
There relatively new but look like a good thing. I just think you will be disapointed with the 35/40 in comparison to something like these. But hey its up to you.
If your not doing anything tomorrow give me a txt
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612445
The results from the GTX so far have not proved they are better at all... More power but more lag; who would have thought?!
Go with what is proven to work you don't need expensive fancy parts to go fast.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612486
I think your parts list is good, you need rb26 pistons with the rb26 crank. I would get premium valve springs supertec/tomei.The nitto pump is fine. Probably better than the Jun.
Edited by WHITE gtt
  • Like 1
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612511
This! What is your budget? Your looking at an easy 10-15k plus the headwork and parts for the head.
So let's say 20k-ish plus because you have to buy all the parts including the turbo. Still keen?
Edited by r33cruiser
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613249
Have everything machined, cleaned and balanced correctly. Have your block decked, bored, honed, also have the main tunnel machined, good bearings ACL (I am going 20 Thou RB25 ACL Bearings), acid dipped. Get the Crank grub-screwed, cleaned and balanced along with your conrods and pistons (as they all are apart of the rotating mass). Make sure the clearances for rings, piston to bore are within tolerances, bearing crush is within aswell.
Crank, depending on how big the oil drive is, you may want to get a oil collar installed too. Also look into doing some oil control too.
A engine build is never really "cheap", I have done a rough calculation for my build, parts alone are around the $10k mark, then machine shop cost on top.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613402
Money isn't a problem for me at all. The Fiance and I have an agreement that we're not getting married until my car is done... So she is helping me out as much as she can too, haha. ;)
Thanks guys, this means a lot. I'll make sure I keep updating when I start working on it. Keep you guys in-check with the progress. :)
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613537
Lol then Godspeed buddy.
Make a project thread ;)
  • Like 1
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613878
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
