Hey guys,
Well, I've decided that this year I'm going to stop 'talking' about doing something to my R33 and actually 'do' something to it... So first is first, the engine. I've been told, but I'm not 100% positive that it would work...
The plan so far is...
40 thou oversized pistons
'H' Beam rods
R33 RB26 crankshaft
JUN oil pump
New Water pump
Bigger oil sump
Garrett GT35/40
Front-Facing plenium
Bigger throttle body
Headwork to suit with decent size cams.
That's the basics so far... I've been told and read that this plan should work, however I've also been told and read online that the RB26 crank doesn't fit. Any help would be awesome. I'm not after Horsepower Hero status, I just want a gutsy road car I can have fun on the track with.
Thanks.
https://www.sau.com.au/forums/topic/349279-rb25-build/
what about just do the turbo, ECU, injectors, fuel pump, wait for the engine to break and then rebuild???
I wouldnt worry about using a 26 crank, if your not after horsepower hero status...
Why do you want a bigger throttle body?
bigger oil sump, do you have an oil cooler as yet?
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5611980
Hey guys,
'H' Beam rods
R33 RB26 crankshaft
JUN oil pump - Check out the Nitto Oil Pump, cheaper and flows the same or better then the Jun, and it's Australian.
New Water pump
Bigger oil sump
Garrett GT35/40
Thanks.
Yes it does fit, I am going down the same path later this year. I have a R34 GTR crank, and I need to buy RB26 pistons (going 20 thou, 86.5mm) and some forged con rods. The RB25 and RB26 blocks are very similar, the major difference is the stroke of the RB26 over the RB25.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612038
At the moment the only things the ol'girl has is a 3 inch exhaust from the cat-back, boost 'T', coilovers and mags... I only put the coilovers and mags on it. I'm buying a seperate engine and everything I need in the next few months. I just want a safe-going, gutsy engine.
Thanks for the information, Aberax. Is there anything specific I need to do to make it all work out, crank wise?
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612187
Only important if you need them - plenty have not required them for over 350rwkw.
Rob - what is the budget/plan/use of the car etc?
A 3540 isn't the best choice for a street car in all honesty, no do you need to spend the extra on rods etc.
The parts list is a bit all over the place. Lots of stuff you need isn't on there, lots of stuff you don't need is...
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612214
2.6 and 2.5 blocks are the same . thats why rb25det blocks have 2 oil feed lugs cast into them
rb26 has longer stroke and lower piston crown height
so if your using a 26 crank you need pistons for a 26
con rods are same dimesion
  • Like 1
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612218
The plan is to have a nice cruiser that I can go to the track and thrash around without worrying a lot about something major to go faulty. That's why I want to strengthen as much as I can. I plan on working the heads and having stronger valves and springs too. 35/40 just seemed to be a good choice for the track/strip but I'm open for suggestions.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612403
Rob, Check these links out
SAU Topic - Garrett GTX Turbos
Garrett Website - GTX3076
There relatively new but look like a good thing. I just think you will be disapointed with the 35/40 in comparison to something like these. But hey its up to you.
If your not doing anything tomorrow give me a txt
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612445
The results from the GTX so far have not proved they are better at all... More power but more lag; who would have thought?!
Go with what is proven to work you don't need expensive fancy parts to go fast.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612486
I think your parts list is good, you need rb26 pistons with the rb26 crank. I would get premium valve springs supertec/tomei.The nitto pump is fine. Probably better than the Jun.
Edited by WHITE gtt
  • Like 1
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5612511
This! What is your budget? Your looking at an easy 10-15k plus the headwork and parts for the head.
So let's say 20k-ish plus because you have to buy all the parts including the turbo. Still keen?
Edited by r33cruiser
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613249
Have everything machined, cleaned and balanced correctly. Have your block decked, bored, honed, also have the main tunnel machined, good bearings ACL (I am going 20 Thou RB25 ACL Bearings), acid dipped. Get the Crank grub-screwed, cleaned and balanced along with your conrods and pistons (as they all are apart of the rotating mass). Make sure the clearances for rings, piston to bore are within tolerances, bearing crush is within aswell.
Crank, depending on how big the oil drive is, you may want to get a oil collar installed too. Also look into doing some oil control too.
A engine build is never really "cheap", I have done a rough calculation for my build, parts alone are around the $10k mark, then machine shop cost on top.
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613402
Money isn't a problem for me at all. The Fiance and I have an agreement that we're not getting married until my car is done... So she is helping me out as much as she can too, haha. ;)
Thanks guys, this means a lot. I'll make sure I keep updating when I start working on it. Keep you guys in-check with the progress. :)
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613537
Lol then Godspeed buddy.
Make a project thread ;)
  • Like 1
https://www.sau.com.au/forums/topic/349279-rb25-build/#findComment-5613878
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
