hey guys,
i'm looking to alter my setup and gain some torque and response.... i'm happy with the power, as i dont want to be breaking things regularly if possible ;)
i'm open to all sorts of ideas but at the moment i'm leaning towards a RIPS 25/30 long motor
i'm planning to use my current turbo (HKS 2835 pro s)
what i was wondering is if anyone has any experience on how a "small" turbo like this performs on a 3.0
does it creep much? does it surge? etc etc
for comparison's sake it's basically a garret 3071 with a .68 rear housing
cheers
I had an rb30/25 NEO with a mildly highflowed r33 turbo, it made 170rwkw @7psi, held boost fine, torquey, but tapered off really fast. You mey find that you end up making the 300rwkw you want at 4500rpm, and 270rwkw at 6000, which is about 1/2 the torque as 4500
You know who to speak to; Al.
He was kind enough to hand over the keys a few times at a deca a while ago. It's a true freak of a car to drive in its own special way. If I had a gtst, I'd get the same setup and some seriously grippy tyres
Adriano is on the money. It would pull like a tractor down low, build boost fast and then torque would taper quickly as rpm rose. Turbine spec is too small to let it breathe up high, could not produce over the same rpm range as Al.
i think i could probably pick up a new 3076 .86 for around the price i can sell my 2835 kit for...
might as well go for the best possible setup for what i want, as opposed to settling
considering the difference will only be a few $$$ and the turbo has to come off anyway
I think you mean 0.82 housing. To be honest I think the 0.82 will be worth changing to. Exactly right the turbo is already off and you will get good money for your current kit. Not to mention the hassle and expense of fitting the current turbo up getting a tune and then deciding its not what you want and having to change turbo again and retune.
Spot on and what you should be doin :D
3.0 + poncams + 3076R = :D
But if you want the most out of it, Disco is right.
Go the 1.06 rear and 650 cc or larger inj.
I just looked at your boost response, looks great, seems as though it beads off pretty quick.. I'm guessing because of the small housing!
So many hybrid motors don't see full boost till close to 4500+ rpm..
I'm also planning to build a 25/30 motor, with VCT running for my next car (whenever that comes)..
they must be running big turbos for 4500+.
my GT35 (0.82 rear ext gate) can pump 18-19psi @ 3600ish
For a streeter.
Going much smaller than a GT30 and you need to look out for the old torque vs rpm vs gearing.
The RB30's choke very quickly with a small turbo and begin hurting over 5500rpm of which seriously kills your acceleration once up and rolling.
If the rpm doesn't match the gearing you'll find you will be shifting considerably earlier and the old rb25/20 setup was quicker and importantly more fun to drive.
GT30 .8 - 2800-3000rpm all its boost
GT35 .8 - 3500rpm ish all its boost
GT35 1.06- 3800-3900rpm all its boost.
Don't let that gt35 1.06 300rpmish fool you the 1.06 does feel a fair bit more dull to the .8 in first and second. The .8 makes more boost at a lower rpm where as the 1.06 tends to making very little then snap on hard. In my experience anyway.
Edited by Amoreuxi
There is also on/off throttle to contend with.
Not only is a larger housing more "dull", it's also going to be slower in/out of gears to rebuild boost and so on.
Also making it easier to bring back up onto boost and just feather it. Given Hamish's use of car, the smaller housing is certainly more suited
Not sure if "dull" is the correct word to use. The 1.06 housing will have some lag and then hit harder.
I would personally choose a GT35 0.82 for an RB25/30 if I ever do one.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
