Hey everyone.
My brother recently sent me a link to THIS and said "You should get these."
I had my original rotors machined about 15,000KM ago and have already noticed they were beginning to warp once again.
So after a few emails to Concept Z, I had the kit delivered to my door 5 days later for $2063.00!!!
Today we decided to fit them!
After removing the old caliper / rotor I threw on the nice CNC machined adapter:
Then we put the new rotors on.... they are a little bigger than stock. :banana:
The calipers are also a little larger too...:laugh:
BEFORE:
AFTER:
Rear:
It was a simple bolt-on.
The only trouble I ran into was having to cut down my front Banjo bolt (I used the supplied rear banjo) and had to run a spacer on the front wheels to clear the caliper.
On the drive home I have noticed a huge improvement in power and the pads are obviously still bedding-in. I didn't notice any change with the additional weight.. but will see how things go through the week. :cheers:
Chris.
  • Like 1
https://www.sau.com.au/forums/topic/349958-m35-big-brake-upgrade-14/
Wow they're HUGE! Great stuff guys, and not that big of a hit to the pocket either. Keen to hear how they pull up after they've really bedded in. This may well be on the cards for me this year :thumbsup:
What size / offset are your wheels? Would be nice to be able to fit them without a spacer.. but somehow I dont think my lowly 17's will cut it :P
  • Like 1
BASTARD!!!!!
I figure on Monday I still should be able to pull away at a fast enough rate to cover the corner from you under brakes!!...atm!
$2,000....linki please!
Link is at the top Craig, jealous much?
zomg. Epic. Found the kit and put the link up a couple of weeks ago on some other site. Awesome upgrade for the money.
Agree ^ about wheels and spacers, but who cares!
Even the colour suits it! Good buy.
yeah you need massive wheels to fit these
Chris has 19 x 9.5 with already aggressive offsets and they still had to be spaced 12mm out to fit. There is also only 8-9mm of clearance between the top of the caliper and rim. So you will need minimum 19's for these to work.
  • Like 1
:cheers: Cheers for the heads up, will have to keep this in mind when speaking to my wheels guy! :D
ok, i've been looking in to this myself as a v35 is next on the cards for me.
the rotors are huge, at 355mm, but from all the information i've read about them they weigh an absolute tonne. the blokes that have done the conversion have said that the increase in unsprung weight is huge and that you are best off buying 2 piece rotors from the start
here's a couple of pics of the g37 akebonos in comparison to r34 gtr brembos
  • Like 1
An awesome upgrade... now you just need to make your car quicker! hehe
So true!
I am sure I read somewhere on a 350Z forum that someone got the kit working at a stock 18" wheel.
holy crap they are massive!!
how wide was the spacer at the front?
I ended up running a 12mm spacer all round. Wheels sit super flush.
Do the brakes and then find wheels to fit! :P
I really couldn't notice any difference to be honest. I wouldn't mind the 2 piece rotors, but I think they are a little out of my price range...
I will see if Ben is keen for a run at the lights tomorrow.
Looking at the I.D. of your wheels Chris, I'm sure they would fit behind the 350GT 18's I bought from you. Maybe measure when you do the 1000km bolt check and I'll measure the 18's?
The only thing I'd have doubts about is the caliper to wheel claerance, the calipers look very wide!
BTW nice pics in the current AMB mag, best job ever?:worship:
Edited by Daleo
FYI
I can get custom made 356mmx32mm 2 piece rotors for around $350 each. Can machine down diameter to suit smaller wheels.
Similar DBA are approx $650 each trade.
Can also get a full drive in drive out custom setup to suit yur car and wheels clearances for around $2600 with braided lines etc. Calipers are 8 pot made in South Africa and discs, custom hats and braided lines and caliper brackets made in Brisbane.
They can also do the rears by attaching a new bigger disk to the factory centre to retain the drum handbrake and use a smaller 6 pot caliper.
Just food for thought
What are the piston spec's on the new calipers?
Are they any better than the factory brembo's, which are not higher regarded as a good caliper. Poor man's entry level really.
Better version is the EVO7,8,9,10 brembo's. Very similar to the F40's version.
Edited by darrinspencer
no good for my nismo rims :(
but looks the goods, thats for sure!
They should juuuust fit, but you'll need to use 15mm or 20mm spacers (from memory)
I have a template for this brake kit that you can print, cut out and put inside your current wheel to see if they will fit... but it is on the home PC. Will post it up tonight.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
