  • Replies 53
Posted Images
Hey Zaver,is your car manual or automatic transmission ? It seems very powerful on the pictures,do you use it for drifting ?
How much power and torque does it makes at the moment ?
Hey,can anyone help me with what should I do or install in my R34 to get more power,torque and more responsive acceleration ?
Right now I think it makes about 230kWs and around 380Nm torque (maybe) at the wheels and does 0-100 in around 6 seconds flat.
I want to make it as powerful as it can,I know it's gonna cost alot but yeah.
And does anyone know what's the maximum power you can get out of an RB25DET NEO engine ?
Thanks !
Okay,what's the best website or where's the best workshop to buy the parts from ?
And I forgot to tell you that I'm running 11PSI on the stock turbo.
You would have at most 180-190kw with stock turbo on 11psi, someone is pulling your leg.
If you want more power then do the usual things, computer, injectors and then get the appropriate turbo for your power levels, highflow will bolt on and make a reliable 250kw fairly easily. If you want above that then you are going to need to get more serious.
Haha really ? I'm not,just bought the car and the previous owner it makes about 220kWs at the wheels.
Okay,what should I do to start with ? And where to buy the parts from,what brand or kind,which type ?
Thanks
i just brought a R34 GTT (man) as well
im looking for response to have some fun in
mods it come with
3:custom exhaust to a 5" tip hurricane
pod filter
HKS dig boost controller
Gtr fuel pump
TEIN full addjustment coilovers
18" widetrack mags
my mods are
i have placed a order with tunehouse for the HKS GT-RS turbo kit ( may end up being a play toy so i thinking for the long run)
injectours 600cc (booked in)
NGK replacment sparky
40mm aloy replacment radiatour
x5 guages auto meter COBOLT oil pressure, water temp and boost to replace x3 guage cluster
also volts and a stage 2 electric shift light system
new rockforfosgate P3 12" punch and 1000wat amp to suit
center consol repainted in mica blue
(mods for next time i get off work)
hks timeing belt
head stripped down and surfaced ground for the new top end stud kit and metal head gasket
turbo smart duel port bov
fuel regulatour
Vipec ecu( removes AFM THANK GOD hate that shit :worship: )
new intake system to suit
it will have a duel stage boost system from the tune std like 7Psi up to around 12 not sure till its all together
est power out put :ninja: unknown lol :ninja:
and other supporting mods my tuner thinks of befor i have to do a full rebuild
( i just sold my Xr6 turbo so i have some spending money :)
WITH THESE MODS WHERE DO PEOPLE THINK MY POWER OUTPUT WILL BE AT?
Well then if you want to do rims and suspensions first, i suggest that you go for some good 18" Jap wheels because 19's cost more and the tires are also pretty expensive for them, Go check out the business trader section for rims they have some good deals there, I personally like the Rota Rims..
And for suspensions i would suggest you go coilovers its the best bang for ur buck for cornering and handling, these are good coilovers and are pretty reasonably priced- http://www.justjap.c...623&cat=&page=1
I dont trust your advice personally... youve suggested 300-320 on stock internals, you've recommended BC coilovers as being good bang for buck, and said 18s are better than 19s purely because of tyre cost...
all of which I think is just crap...
i have to say that 18's are better than 19's for a few reasons, but cost of rubber is defiantly one of them :)
and yes it sounds like a bearing went on vacation, will know for sure soon :)
mods it come with
pod filter
Gtr fuel pump
18" widetrack mags
my mods are
hks timeing belt
fuel regulatour
The HKS GT-RS actuator is a 1 bar one so the lowest you will be able to run is around 14psi give or take. (currently mine is running on the lowest boost I can run and it is about 0.8-0.9bar). On that sort of boost pressure as long as everything else is up to the job you should see around 220-240rwkw dependent on dyno.
Well i only suggested 300-320 is because most people want to push their engine's, and people are running 300kw engine's safely as i have spoken to some tuner's, thats if they aren't pushing it hard all the time, As he has said he will be using it for the street, BC coilovers is because he just wanted to put lowered springs and from that it would be a better step to upgrade to coilovers, I didn't say they are the best, but he will be using his Car again for the street, i have Tein super street coilovers and would have recommended him that but it costs $2200 and im not sure if that would be in his budget, Yea well again 18's is because its lighter than 19's and he occasionally would like to go to the track and when he has to buy tires for his 19" rims for the track its definitely going to hurt his wallet..
If you have a better solution please enlighten me as well as him, Dont just say that its "Crap", Remember he is on a budget like most of us, maybe u can afford to blow crazy amounts of money on ur car, not everyone can..
Hey buddy, my car is manual.. I use my car on the streets but occasionally go drifting and to the circuit, i like to keep my car as a all rounder where i can use it on the street as well as the track.. My car is mostly stock apart from the basic mods that even you have and has 200kw's.. Im not sure on the torque.. In my other thread iv listed out my mods and the mods im planning on getting to make more power, you can check it out as even im spending my money in the budgeted but right way.. You can choose to follow the mods im going or do it ur way.. http://www.skylinesaustralia.com/forums/topic/350133-need-advice-on-build/
I thought it was reasonable advice personally. 18s ARE better than 19s lol, like you said, cheaper rubber, lighter and almost always better performance.
The main goal of the HKS GTRS is response, if you have a look through the dyno thread there arent many making any more than 250rwkw but they do provide great response.
Another option is the HKS 2835 Pro S, slightly reduced response and capability for 280-290rwkw. IMO a better overall turbo for the RB25, but if response is your main goal go the GTRS.
wen im done with all my mods if it makes 250rwkw ill be happy as a pig in shit i dont want i dyno buster or anythink stupid just a fun toy with grate response to play with
  • 3 weeks later...
I just found out today because my car is an automatic,it'd cost around $3,500.00 to remap or install the new piggyback ECU or something ? Not really sure.
What piggy back ecu? Nistune fitted and tuned for around $1,000 is fine on an auto.
Your automatic is controlled via the nissan ecu. The best way is to use Nistune as suggested above as the gearbox settings can be tuned directly. Otherwise if you get another ecu you will need a separate gearbox controller or something??
Summary get a nistune!
Check out the places in Perth that use Nistune:
http://www.nistune.com/ordering-distributors.php
    • Got the gearbox in and the front drive shafts.
    • Hi There I went through a rabbit hole of reading about Xenon headlights and the ADR regulations for having them installed. As people have been defected by running factory xenon I was researching in ways to make them compliant. Everyone always say needs to be self leveling and have washer installed, which I don't necessarily agree with. For this argument I'm using R34 as reference as I'm more aware on the construction of the headlight compared to the R33 Xenon, which may still be the exact same case.   For the self leveling clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles As you can see the bold text "these manually adjustable devices from driver seats" are fine to use. As Series 1 Xenon model headlights do have a 4 level adjuster on the right near the ignition (however not series 2) then these model are consider compliant in that argument.   For the Self Cleaning aspect of this argument clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles Now i can understand the argument that Xenon will need a washer as they are over 2000 lumens, but I clicked on the 12 at the end of that sentence and it takes me to the end notes which states R34 for headlight lenses are plastic, not sure if PL is mark as I don't currently have my skyline to confirm that marking is there. But could you not technically get a lenses with the PL marking on it and then get away with the argument that you need a washer. I went through a quick read of the adr and might have missed something else that may cause them to be non-complaint.    But wouldn't these technically be complaint headlights   Would love to hear other people input on this and shed some light   Edit In regard to the the washer portion I might be mistaken ADR 45 (which I believe is Regulation NO.45) states 12 cd (candela) I dont understand that portion in regarding to calculating the candela if anyone can shed some light. Otherwise I guess throw in a washer for the headlight and you definitely comply.
    • Took it to all Japan day, flogged the hell out of it and took it all, am a very very happy man  don’t know how that ended up in Greg’s thread before
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
