interested however this seems a little exy when you can get a 330mm kit with lines for $1000us delivered?
pm'd you dude
PM replied.
Completely different cheap Ebay kit with completely different calipers and rotors.
Phil, Im in, once again :)
Excellent!
BUY LIST
1. PMR33
2. DVS32R
3. NA BEAST
4. .....
5. .....
I'll speak to Hel this week about sorting out the brake lines and I'll PM every one to see what they want to do (whether they want to get their own or get some through me). If the guys that have signed up for the front kit want to get a rear kit, it would be best just to get Hel to make up a full front and rear kit for all of us.
All that is different is the fitting into the caliper. So simple enough to get some new Hel lines and sell the old ones (that's what I'm doing). I'm sure you could use some sort of adaptor fitting but that's a bit dodgy.
We are ready to go!
My mate is going to grab the kit, if it doesn't clear his wheels without spacers than we will just try and sell it on ebay or something. Pretty sure it would sell fairly easily.
I will start PMing every one tonight with details.
:cheers:
Phil
In the next couple of days I will hopefully have an answer to what we are doing about the rear kit :)
I have looked into all the options available and I think what I have come up with will be the best choice. Will let you know as soon as I hear back from Daryl to see what he thinks about my suggestion.
One payment has all ready come through, so as soon as the other two are in my account i'll put the order through.
REAR KIT UPDATE
Just thought I would update on what we are doing with the rear as the handbrake is causing this to be a pain in the ass. Basically here's what I have found:
The option with having the drum handbrake completely dissapear and replaced with an additional single piston caliper is going to cost a lot of money (way more than the front kit) and also not really be suitable for people doing Motorkhana events. The drum handbrake setup is apparentely a lot better for this. Also even if money wasn't an issue, to get it to work with the Skyline rear is a challenge in it self and may not work with out a bit of modifying. So I don't think this option is viable for a group buy situation.
The next option was to build the handbrake into the main caliper itself as Wilwood have one caliper that does this. With this I have found that first of all the Skyline handbrake setup is not directly suitable and would once again have to be modified to fit correctly. Next the calipers are very small and not made for large rotors and also for such large/heavy cars. Also they don't make a good variety in piston area so to get something that would work in harmony brake balance wise would also be difficult. Overall it once again aint a viable solution.
The final option is to keep the drum handbrake, but once again there is a problem. Wilwood do not make a rotor to suit our drum handbrake.
So this is my solution that I am currently looking into which should work well and be the cheapest option.
We shall use a DBA 4000 series wiper-slot rotor suited for a Skyline hand brake and to this we shall match a Wilwood 4 piston caliper. The largest they seem to list for the Skyline rear is 300mm x 22mm which is what is on the Brembo R33/R34 GTR (GTST/R32 GTR has 297mm x 18mm). However I can email them to see if they do a little larger diameter. I just have to confirm piston area size on the factory rears so I can mate up the correct Wilwood caliper suited and also suited for the rotor size. If all goes well and I can match something up the rear kit should easily be between $1000-$1500.
So I will give an update as soon as I get more information :)
  • Nope 1
I've been in contact with a company in the UK called DB-Power. They sell a bunch of Wilwood kits. Apparentely they will have a Skyline rear kit available in the next week that they have put together so I am going to wait and see what it is and whether it is something we would want.
Will keep you updated.
Also regarding payments. Just awaiting to hear back from NA Beast and also from my mate that I will see this weekend.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
