Well I went shopping with my mum and bought her some cream eggs to cheer her up. The whole time the only thing I could think of was the tv add "how do you eat your cream egg"
WELL.. I bite the head off, suck the insides out and eat the shell.
I AM talking about a cream egg! :angel: :bahaha:
(MENTAL NOTE: Dont go shopping whilst hungry. Strawberry wagon wheels are very nice too, except I'm feeling rather crook now)
https://www.sau.com.au/forums/topic/35035-how-do-you-eat-your-cream-egg/
we once had a batch of them here.
1) i used a straw :(
2) i poked a hole in it and sucked out the cream leaving the shell... hole caved in by the time i was finished :
3) i attempted eating it whole, but that didn't work
in conclusion, cadbury cream eggs are too ****ing sweet and i'm now going back to victoria
well if the women ask, i like to slowly caress and pamper the egg and massage it into my mouth...........
but really, i just keep biting till there is no more left!!
I saw you today erin near indro shopping town between the bp and the maccas. I was in my multicoloured car!!
I was on my way home :(
Coronation drive was ****ed so I decided I would go the back way home. Took be ****en 45 minutes :( Stupid peak hour traffic
I was out in that yesterday... stop, start, stop.. then someone up the front decides to move 50cm closer to the next car, so the whole f***ing lane for 3km back ends up moving too!
To make things worse, some bastard in the next lane is eating a cream egg really really slowly.
ahhh yes, that round a bout at indro is getting balistic. They need to make a indro roundabout bypass!!!! I have been skipping coro drive lately and cutting in and going along milton rd and then jumping on the inner city bypass and it's clear sailing once you are past the red hill/kelvin gr rd turnoff. I hate driving my car to work and back tho, just puts too many klms on it and it needs more maintenance time etc. Lookin for a little datto or corolla to run around in!!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
