Wondering about how many Ks what went wrong for those of you who have been unlucky enough for one of the above or something else to go bust on you, would be interesting to see if this is a age of the part or an amount of use "ks" related thing. As my car has somewhat higher ks than other V35s out there yet im only starting to have issues now
The reason Im asking is because my car now has 84k, I purchased it with 50k. Up until a couple of weeks ago I had never had a problem with the car until the drivers side window motor decided to give up
Sure enough as some of you may have read I ended up fixing the problem by cleaning the motor and putting everything back together
Now the last couple of days I have noticed that my drivers side door has not been locking/unlocking all the time when using the remote on the key
I pulled the door apart again today to see if any of the lock cables had come undone but everything was in its place
Iv read up on the net and again like the window this seems to be yet another common problem for G35/V35s
https://www.sau.com.au/forums/topic/350565-ks-on-cars-when-things-break/
i cant remeber k's when i bought my car, have to check the books, but now with 58000kms window for ps went out, getting it replaced with a brand new oem that i have coming in this week, just waiting for call to book and appointment to get it pro done. im selling the car so i dont want any complaints or faults from it when a person comes to inspect it...which so far has been no one lol.
Edited by ezy03
I bought mine at 76,000kms in 2008, and it's sitting at 89,000kms now.
Problems are:
1. Window motors gave up around 80,000kms (1st was the driver side, a month later was the passenger side).
2. CD player (OEM) makes abit of stop-start when playing music in the first minute or so, and then it's fine afterwards.
3. Fuel gauge needle doesn't go all the way up anymore after filling up full-tank around 80,000kms.
4. Tiny bit of rattling noise when going up driveways lately.
That's about it. Otherwise, it's fine. :)
Edited by Victor.T
Our 2003 V35 Sedan (65000km's) hasn't had any issues yet. The only thing I hate about it is the fuel gauge. As soon as it hits 1/4 it shoots down like tomorrow. I was panicking one day as I visited a mate (Yin Sun on here) as the wife and I left the fuel gauge was on a 1/4 as we went around the corner it shot straight down and the fuel light came on. I crawled it around the block to the nearest servo and I was pulling in the fuel gauge went back up to just under 1/4! I put some fuel in it anyway and asked the wife (she drives it the most) as soon as it hits on or near 1/4 fill the bitch up! But other than that it has been fine.
Edited by omp
At about 78,000 kms my driver's side power window was playing up. I Took the door trim off and pressed the reset button. This fixed it. Now it has 80,000 and so far so good.
Yeah, driver's side window not working is more painful to live with. I used to park at multi-level car parks before I put on my kit. When the driver's side window didn't work, I had to open the door to get the ticket in and out.
Quite embarrassing when you go on cruises with friends. :P
Edited by Victor.T
OH yeah where is the reset button located???
my Drivers side went completely and replaced it.
now the passenger side has started playing up
Cheers
Mine's at 92,000k's and my passenger seat won't slide forward when you get into the back.
Stopped working at around 89,000k's, Other than that, everything else is fine.
So, how do you deal with that issue, Bee? Can you still push the seat forward?
I can still use the button, just wont do it automatically.
Doesn't bother me as i hardly has people in the back seat,
Will eventually get bride seats later on in the year.
Iv been wanting to get a bride or similar seat for my car but the whole airbag thing kind of put me off it. Whats the deal with the airbags when you pull out stock seats?
car is currently sitting on 76kays
couple of months back the window failed to go back up after opening the driver side door...realised coz there was wind noise when driving...only happened the once tho so knock on wood.
single click on rear axle when going to D from R, heard its a common problem but requires rear driveshaft to be removed, greased and rotated...cbf coz i'm not really a DIY person
other than that it drives superb
with 'creativity ' its doable.
though pulling the stock seat out tends to piss off the SRS unit.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
