32 as of a month or so ago...
Is it pony tail and red convertible time yet?
You do one, I'll do the other.
Lemme know what you go with. Although I'm not going sparse on top so I'm not sure I'll pull off the slightly balding ponytail look properly. Might be best for me to do the red convertible and the 19yo nympho girlfriend. You do the chrome dome panytail :laugh:
I'm 22
I helped an oldie cross the road the other day, see some people do still care.
You'll always be a winner Chantalle.
So, if you see me with an aluminium walker in my left hand and a white cane in my right, you'd be prepared to help me across the road all the way to my gtr driver's door?
You would?
Jeez, I'm a winner too; even before the old blind disabled fart-driver turns the ignition key! Yay! :blush:
Yeh I think so, for me too ;p but I already have the long pony tail so all I need is a nice red ferrari ;p
Happy Birthday Kinkstaah. One year old, not any wiser???
Terry- Lol I might be to jealous to help you to your car...old blind GTR driver. I actually can't stand these ol' fart GTR drivers that get in front of me and drive like grandmas, and take a zillion years to get up to the speed limit
  • Like 1
20 til the end of the month
You guys are lucky. You get to celebrate at both 18 (when you become personally responsible for criminal acts) + 21 (when you can start calling all the oldies by their first names and drop the "uncle"/"auntie" business).
Oh yes, and don't forget the the two large cakes!!! :woot:
Not Me!
I drive by sound - not by sight! lol
Gotta beat that 'Doppler' (effect) :thumbsup:
Well Happy 30th Birthday! One year wiser ;) Have a great day.
lol thanks :P
That said, the day was awesome apart from the fact that my damn car broke down, twice. This is in addition to it breaking down on thursday. The stress of this may have added a few years I think.
Im ar, thur t3, beleive it or not. i probably should be driving a wagon but i never was stereotypically normal.
People look at me kinda funny when i have the baby seat or dog or both in the back of my skyline
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
