hey all
im not sure if my manifolds have been port matched to the -7's i have installed so im thinking of removing them as i see its a common thing thats done on most twin setups.
is it worth taking them off to do this before my tune in 2 weeks? im hoping to run 1.3 bar through them
labour will be free but ofcourse ill have to use new gaskets so that will be the only cost
has anyone done back to back testing with and without port matched manifolds? would it be a waste of time for my 320kw goal?
thanks
oz
https://www.sau.com.au/forums/topic/351038-port-matching-7s-to-rb26-manifolds/
I have been porting engines for years and I would say you need to match port things if you want them to flow as best as they can.
even if the turbos are bigger than the manifolds you will create an eddy as it goes into a bigger area and the tumbling effect shows up in reduced flow.
This shows up on the flow bench big time.
And as plenty have proven - what occurs on a flow bench isn't necessarily what actually occurs under boost/pressure/heat etc.
And plenty has been proved on a flow bench as to what works as well.
If you dont want to port match its cool and up to you, its a free world after all.
From memory I read the autospeed article about changing the GTR turbos and thought the overall result was less than mediocre. They port matched the manifolds and ran -7s IIRC.
Most people on here acheive close to the numbers you want without touching the manifolds, thus I would simply follow suit.
I have always wondered though, which turbos come with the cut size T25 flange and which come with the full size T25.... I would IMAGINE the full size flange to be on something -10 size or possibly even the -5s. Can anyone confirm?
Running a full size T25 entry turbine housing on the stock manifolds would definitely warrant porting IMHO.
Port matching will aid "max" flow.
Leaving the manifolds std with smaller turbo's is not a bad idea as response can be effected by opening up the mani outlets.
If the std mani's aren't a great restriction at your power level ie: less than 2.5 x boost pressure. The effort may not be worth it.
If you would rather 10kw up top rather than the mid range then go for it. I would be aiming for average power(nice meaty mid range)
matt
if there already on the car just leave it.
If they weren't on the car you would just have the turbo flange on the manifold opened up to match the turbine housing flange.
You wouldn't go to the expense of port matching the manifold to the head unless you were getting pretty competitive with your car.
I was thinking of port matching my standard manifold to match -9s, but everyone I've spoken to have said it's not worth it as response will be lost, but for -5s and bigger it's generally recommended to do the port matching
I am surprised how anyone can look at the fitment of turbine housing to exhaust manifold flange, notice the overlap, and not attack it with a die grinder at least so the ports match! I would be amazed if measurable response was lost; and I would feel better knowing I fixed something that looks like s**t.
thanks for all the responses guys, i have decided to leave them as is
cheers
It's not worth the effort to pull the whole lot down again... 6 years ago I made 400rwkw on my 130k 26 with stock- unported manifolds.
J.
J.
if you dont mind me asking, what turbos did u have bolted up at the time?
J.
Yes you are right Justin; should have add, if they are already off... do it... if not; next time!
Look at a 6BOOST maifold, particularly the flange...he has purposely left a lip around the flange and even gone as far as testing the shape of the exit at the flange, lip + oval shaped exit...his manifolds are second to none...
I think youre wasting your time match porting the flange, you then have the factory runners with all the bumps and casting lumps in them anyway. Just leave them, lot of work for little if any gain at all.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
