just bought a skyline r33 gtst a few days ago
want to know why its overheating
it started overheating today because the previous guy put techaloy 60 in, i filled it up with 90, the reservoir was at full mark, and when it overheated it went about 3-4cm above the full mark and the radiator had barely any coolant in it, n the coolant in the reservoir was boiling for about 10-15 mins...
so i did a coolant flush, put techaloy performance 100 in
but after about 30-45min drive it started overheating, the coolant in the reservoir was almost empty (was up to the full line before) but the radiator still had the right amount of coolant in it...
i cant figure out the problem, the cap seems alright, the thermo was opening because it was able to bleed the coolant
p.s. when it overheats it only ever got to the white line iust before it hit the hot mark (the white line is bout 5mm before the hot line), so it never hit hot
anyone got any ideas? much appreciated
Edited by caliibre
https://www.sau.com.au/forums/topic/351043-r33-gtst-overheating/
Im guessing you have checked for leaks?
Doesnt need a very big leak to start overheating, and if your loosing coolant to then that seems like the obvious cause
thing about the factory water temp gauge is as soon as it moves above where the operating temperature (which is just under half way) it means your water temp has hit 105 degrees. if its hit that a few times you've probably blown your head gasket.
a few ways to check if you've done this is to check for the following;
- milky substance in your radiator or oil cap (if its cracked through an oil galley)
- constant bubbles in your coolant (if its cracked through your combustion chamber)
- white smoke out of your exhaust (water going through your combustion chamber)
are you getting any of these?
yeah i thought i might have blown my head gasket but
-dont have any milky substance in radiator or oil cap (though when i pumped the old coolant out of the reservoir towards the end it looked clear almost like water, kinda milky)
-dont see anything wrong with the bubbling side of coolant
-not sure about white smoke coming from exhaust
new radiator cap ay?
The first tip happened to my R33 GTR just last week and i have done the gasket maybe a cracked head. Mine has oil getting into the coolant . I noticed mine getting when it was to late blew a big hole in radiator hose. Hope yours hasn't done the same thing i am up for big $$$ to fix it.
possibly try a new cap and see if that makes a difference (make sure you get the same pressure cap).
possible causes of overheating are:
dodgy cap
dodgy thermostat
leak in the system (including blown head gasket)
dodgy water pump
blocked radiator (which a flush will do nothing to help)
shagged clutch fan (although driving at highway speed it won't overheat)
had mine up to 119 on powerfc readout twice after the water pump leaked out the telltale hole and it was only half full. got it to a mates both times and fed water into it real slow. did another 50000km before rebuild due to damaged rings but head was ok. maybe i was just lucky but mine was well into the red so yours may be fine too
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
