Hi,
Can someone please explain to me in very simple to undersand terms, what the fark wheel offsets are and how to choose the right ones ??
For example: I have 17" x 8" wheels on the front and 17" x 9" wheels on the back of my R33 GTS-t.
The dish size is different front to rears, as expected - is this just the diff in width or does offset have something to do with it ??
What is the ideal offset (without having to use spacers) for 17" x 8" (fronts) and 17" x 9" (rears)
Are these the best size (width) ?? or should I look at going wider by 0.5" per wheel ?? If so , does this change the offset???
Please Explain ???
Cheers,
Brendan...calculator here:
http://toy4two.home.mindspring.com/offset.html
And once you've worked out the answer, how about posting it in the FAQ section, coz this gets asked a lot....
well, from meggala's site (great info! http://www.meggala.com/wheelsoffsets.htm) stock wheel sizes and offset for r33 gtst is:
F: 16 X 7.0 +33
R: 16 X 8.0 +38
the problem is I've got no idea of the clearance inside and out for the stock wheels so I can't use the calc either :P Anyone got those measurements?
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
ZERO OFFSET
The hub mounting surface is even with the centerline of the wheel.
POSITIVE OFFSET
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
NEGATIVE OFFSET
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
  • 2 months later...
So basically their is no "set" offset for each car it just depends on:
* How you want it to look
* How the car will handle
ie; the difference between an offset of 35 and 38 is 3mm which will effect either looks or handling/supports.?
Err yes there is a "Set" offset for each car, especially when your talking about a skyline. 4 pot brakes make it mighty difficult to bolt on just any rim with any offset.
My 32 has +35's all round... the difference between a 35 and a 38 is minimal in terms of looks, and id doubt itd make a major handling difference.
Bear in mind not all rims come in all offsets, which means its quite common for people to buy a set of second hand rims without thinking about it only to find it doesnt clear the brakes or sticks out the guards by a good few cm.
Red17
  • 6 months later...
Guys, if you want a better understanding of wheel offset and backspace, read this page - http://www.usacomp.com/Offset.htm
It's probably the most useful page I've seen which best describes wheel offsets. I know this has always been a confusing concept for many people, but once you understand it's really quite simple.
Cheers.
:P
Absolutely. Offset can change the wheel track, more (posative) offset = more track width.
but of course you still need to clear the brakes and suspension on the inside, and be careful of moving the wheel out beyond the standard guards, also illegal :)
On my new 18's i got +38 offset front and back, but the front brakes just clear the rims, like 1-2 mm, so i would go +35 offset for the fronts B-man. I had no choice as they didnt have +35 offset for my rims.
You see alot of skylines going around with the wrong offsets that makes the rims sit inside the guards coz some tyre places dont know shit and will just supply fwd +45 offsets for skylines, which looks shit.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
