Does anyone have information about cat converters for high power (say more than 300kw) engines? In NZ it is now a requirement to run a cat and you can't get a cert or a wof without one (except for track cars). I have searched this forum and spent a few hours on the internet. The best cats seem to have a steel or metallic rather than ceramic core but very few state a flow figure or even a power rating and most have a maximum diameter in and out of 3inches with the odd one at 3 1/2 inches. Those that do give a power rating seem to max out at 300kw. This would be enough for most street applications but I am sure that as these regs have been in place in Australia for a lot longer than in NZ and there are quite a few street cars with more than 300kw you must have come up with some solutions or does everyone just replace the cat with a straight pipe? Are there cats bigger than 3 1/2 inches or do you have to run two pipes and two cats to be legal? Would be interested to hear if there are any single cat solutions for big power applications!
https://www.sau.com.au/forums/topic/351469-high-performance-cat-converter/
Spoke to one of Sydney's leading exhaust shop a fair while ago. Was told ceramic core cats crap themselves under high hp...gets blown to bits or collapses/melts etc and he recommended a metal cat and said the magic cat brand (or was it metal cat) was the one to go for from memory. I'm pretty sure you can get these upto 5".
Then again, my line at the moment is running a ceramic high flow @250rwkw and it's fine..cats old'ish too.
Greg from sure has sent me the following:
Our Ballistic 100cpsi Racing Cats are available in 4” body, 4.5” body and 5” body.
The 4” and 4.5” are available up to 3” pipe size.
The 5” body are available in 3”, 3.5” and 4” pipe size and the 4” pipe size flows 1023cfm.
The 4” body are $230 each, 4.5” body are $270 each and the 5” body are $340 each + $16 for delivery.
All are in stock. The bigger the body the better they flow.
They are sounding very good. I have a HKS front pipe (3") and HKS cat back (3.5"). I was going to get a 4" pipe but I'm concerned about turbulence?
While they sound very good they aren't old in and need flanges and nuts for the sensor.
This is an easier proposition:
http://www.justjap.com/store/product.php?productid=16440&cat=275&page=1
Just worried it might be too small? But I'm worried 4" is too big for the system. When people say 4" are they referring to the body or pipe?
That add says 3.5in flanged - that is for a 3.5in pipe, and the cat body is larger than that, probably 4 inch. Check the catco prices as well. The flow measurements are meaningless without stating what be pressure is....
I have this one fitted right now:
http://www.justjap.com/store/product.php?productid=18066&cat=275&page=1
Which has been pointed out as too restrictive for my -5s, HKS exhaust, etc. Currently sitting on 300RWkW and looking for more.
No I'm confused, when Ash et al say you need a 4" cat at least, they are talking about the body not the pipe? LOL
And you're right, pressurising something hard as so it flows is pretty meaningless. Sounds good though.
So i'm looking at getting a Venom cat. What series would best be suited for my skyline , 450 or 500 series ? Has a full 3 inch exhaust system from turbo back & is making 290rwkw at the moment. I want the best flow possible , would the 500 series be to much of an overkill ? :thanks:
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
