I have a 1992 R32 gtst with the following mods:
- HSD coilovers
- adjustable castor rods
- Hicas lockbar
- Pineapple bushes
- Slotted rotors
- QFM pads
- 3" turbo back
- gutted cat
- RB25DET+box
- KKR430 turbo w/ 1 bar wastegate (i know i know)
- cheapie FMIC
- blitz suspower pod
- exedy clutch
- Microtech LT16 with hand controller
- sard FPR
- OS Giken cam gear
- Gates racing t/belt
interior and exterior are essentially stock (just type m kit)
was thinking next steps are diff, seat(s), cage and susspension arms/sway bars
anybody got ideas on what I should get, also good chance to sell your shit if you are selling
https://www.sau.com.au/forums/topic/351587-what-should-i-do-with-a-spare-2000/
I would go a better turbo, but then u need afm, injectors and fuel pump so thats about ~3-5k
so instead I would go a decent non restrictive cat so you dont get f**d if you get pulled over and some rims.
hey guys, yea I want performance, but in a holistic sense (so handling too) JDM drift pig lol.
I am not after subs, more weight, have a decent head deck and speakers.
sorry forgot to mention too that I have 17" Enkei Racing S wheels (cant afford TE37s or Meisters lol)
also have walbro fuel pump and the microtech has a MAP sensor so no AFM woes for me lol
lol 2k is a long way off that 35
eney how i would say get rid of that shitty kkr.
but on the other hand maby do the cage and susspension arms/sway bars make it handle better.
seat would be good as well
Edited by whitenight27
Larger injectors, new turbo and tune!
car will get a high mount in about a year...don't want another low mount. so since I can't afford the manifold etc so no new turbo atm
and I only have 2k to spend, the car was tuned last week...so mainly handling and seats, diff etc
Ok off to the handling area then :D
Far better responses in there :)
haha yeah sorry bout that, thanks :D
yea was thinking sway bars and camber arms, is it possible to get a 1.5 or 2 way for 500 to 1000 bucks?
What tires are you using atm?
2k..
f/r adjustable swaybars - 500
second hand lsd - say 800
aggressive street wheel alignment + corner weighting - $350
Strip the car (start with boot and rear) depending on personal preference/usage - free
Bit of money left over for install help if you cant diy/some replacement bushes.
Depending on how low it is, you might not need adjustable sussy arms etc. The factory stuff gives a small range of adjustment and is generally enough to do an aggressive street setup if the car's not too low (check the bushes condition though).
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
