Sorry should of been more specific, it has been replaced with a reconditioned one for $150.. so i was pretty happy with that considering he told me a brand new one would cost me $800 from nissan.
Which car was yours Scooby?
Edited by Aleckr33
Bargain, nice work. Mine was the Grey 32 GTR.
quickest and easiest way to test the cat is to drop it and run the car on the dyno with just the dump/front hooked up and see what sort of difference it makes. if its 5-10kw then the exhaust isnt your problem. if it jumps 20+kw (might need retuning, less pressure means you can run more timing) then you have a restriction
BINGO!. no need to take it somewhere to test. it's a 10min job to unbolt the cat. and most workshops would have a bolt in de-cat pipe around (if so even better as it means no exhaust spewing out the middle of the car in the dyno cell). then back on the dyno and see if there's any change.
He could be getting bungs welded on to measure back pressure with a gauge but why bother.
I went to an exh shop once to get some bungs welded on for that purpose as I didn't have access to a dyno, but the owner reckoned he had just the thing to measure back pressure and produced a pencil gauge with a needle fitting that he proceeded to stick into a tiny hole he drilled in the pipe while asking me to rev it. At this stage I was staying with him out of curiosity. After 3 goes he pronounced it free as a bird. Excellent (bollocks). When I did get to using the dyno I found the cat was costing me 20rwkw.
That's the one Steveo. I removed the TT badge etc and cut the bracing. Bloody horrible but there wasn't another solution at the time (or one that I could find) and I'm not sure that's changed.
Fair enough but i dont agree that the it will get the heater working faster.
In my car with an oil cooler and a low temp thermostat it runs at 75 degrees on the dyno.
I do agree with a blocked radiator it wont cool correctly as u guys have said. But i would still get a nismo low temp and put it in. If the thermostat opens earlier than the coolant can be kept cooler from 62ish degrees instead of reaching 72 degrees and then slowly open and by the time the coolant has cooled and circulated through the motor the temp is up to 80+.
If it starts cooling at 62ish then its got a better chance of being kept lower.
Yavuz has noticed alot of Interferance with CAS signals on skylines lately. . Do u have a pic of the dyno sheet to show what he means
Have you guys ever thought about the fact your motor is designed to run at a higher temperature, so that it has the correct tolerances?
When you change the running temp away from what it has been designed to run at, you are causing more wear and tear?
yes i have thought of that, but on the circuit most cars without the cooling mods run at an even higher temperature than designed,you also need to take oil viscosity into consideration when talking about tolerances
Pressure test was done, turned out the ceramic catco cat was holding back about 20rwkw. It is now gutted lol.
After that Yavuz put it back on the dyno.... Results were going good till the clutch started to slip at around 220rwkw, got a bit of grip, then slipped again at 260rwkw :( so he stopped immediately after that. Car will be going back after i put a NPC 5 Puk button.
boost was at 19psi peak, drop off to 18.
dyno sheet isn't very clear, sorry. On the right side is the NM of torque.
Edited by Aleckr33
Update.
Yavuz called me today and said the CAS is now fixed, Idle control valve is fixed and the car seems to be running ok temperature since iv done the radiator flush. He said the car is currently making 250rwkw but is restricted. He thinks it could be the cat? ... the thing is i just purchased this high flow catco cat from Just jap a week before i gave the car to Unigroup... im not really keen on changing this because it's brand new obviously and thought it would be sufficient for the 250rwkw - 300rwkw mark.
Anyone else have any issues with a Catco cat? What power are you making if you have one?
Cheers
LOL... I've bought this up in a thread somewhere and the moderators were not too impressed with me bagging out forum sponsors.
  • Like 1
I dont think this test is applicable to testing for a cat causing a 20kw restriction. When the car is free revving there is no load or boost to contribute to air travelling through the cat. Its more a test to see if the cat is seriously blocked.
I agree he should not say it is free as a bird as it is only a very simple test.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
