Sorry should of been more specific, it has been replaced with a reconditioned one for $150.. so i was pretty happy with that considering he told me a brand new one would cost me $800 from nissan.
Which car was yours Scooby?
Edited by Aleckr33
Bargain, nice work. Mine was the Grey 32 GTR.
quickest and easiest way to test the cat is to drop it and run the car on the dyno with just the dump/front hooked up and see what sort of difference it makes. if its 5-10kw then the exhaust isnt your problem. if it jumps 20+kw (might need retuning, less pressure means you can run more timing) then you have a restriction
BINGO!. no need to take it somewhere to test. it's a 10min job to unbolt the cat. and most workshops would have a bolt in de-cat pipe around (if so even better as it means no exhaust spewing out the middle of the car in the dyno cell). then back on the dyno and see if there's any change.
He could be getting bungs welded on to measure back pressure with a gauge but why bother.
I went to an exh shop once to get some bungs welded on for that purpose as I didn't have access to a dyno, but the owner reckoned he had just the thing to measure back pressure and produced a pencil gauge with a needle fitting that he proceeded to stick into a tiny hole he drilled in the pipe while asking me to rev it. At this stage I was staying with him out of curiosity. After 3 goes he pronounced it free as a bird. Excellent (bollocks). When I did get to using the dyno I found the cat was costing me 20rwkw.
That's the one Steveo. I removed the TT badge etc and cut the bracing. Bloody horrible but there wasn't another solution at the time (or one that I could find) and I'm not sure that's changed.
Fair enough but i dont agree that the it will get the heater working faster.
In my car with an oil cooler and a low temp thermostat it runs at 75 degrees on the dyno.
I do agree with a blocked radiator it wont cool correctly as u guys have said. But i would still get a nismo low temp and put it in. If the thermostat opens earlier than the coolant can be kept cooler from 62ish degrees instead of reaching 72 degrees and then slowly open and by the time the coolant has cooled and circulated through the motor the temp is up to 80+.
If it starts cooling at 62ish then its got a better chance of being kept lower.
Yavuz has noticed alot of Interferance with CAS signals on skylines lately. . Do u have a pic of the dyno sheet to show what he means
Have you guys ever thought about the fact your motor is designed to run at a higher temperature, so that it has the correct tolerances?
When you change the running temp away from what it has been designed to run at, you are causing more wear and tear?
yes i have thought of that, but on the circuit most cars without the cooling mods run at an even higher temperature than designed,you also need to take oil viscosity into consideration when talking about tolerances
Pressure test was done, turned out the ceramic catco cat was holding back about 20rwkw. It is now gutted lol.
After that Yavuz put it back on the dyno.... Results were going good till the clutch started to slip at around 220rwkw, got a bit of grip, then slipped again at 260rwkw :( so he stopped immediately after that. Car will be going back after i put a NPC 5 Puk button.
boost was at 19psi peak, drop off to 18.
dyno sheet isn't very clear, sorry. On the right side is the NM of torque.
Edited by Aleckr33
Update.
Yavuz called me today and said the CAS is now fixed, Idle control valve is fixed and the car seems to be running ok temperature since iv done the radiator flush. He said the car is currently making 250rwkw but is restricted. He thinks it could be the cat? ... the thing is i just purchased this high flow catco cat from Just jap a week before i gave the car to Unigroup... im not really keen on changing this because it's brand new obviously and thought it would be sufficient for the 250rwkw - 300rwkw mark.
Anyone else have any issues with a Catco cat? What power are you making if you have one?
Cheers
LOL... I've bought this up in a thread somewhere and the moderators were not too impressed with me bagging out forum sponsors.
  • Like 1
I dont think this test is applicable to testing for a cat causing a 20kw restriction. When the car is free revving there is no load or boost to contribute to air travelling through the cat. Its more a test to see if the cat is seriously blocked.
I agree he should not say it is free as a bird as it is only a very simple test.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
