Hey guys my name is Sherry.
My first Car was a Nissan Skyline TI. Now i finally have my full license i want to turn my car into a burnout car for events at eastern creek and summernats.
Im not too sure of what i want to do with it yet, But i want to keep it naturally aspirated.
I am thinking a 460 BB but i dont want to be greedy, also possibly thinking a 5lt. But i also do realise i need to consider power to weight.
Any Suggestions are more than welcome!!
Thanks :D
https://www.sau.com.au/forums/topic/351831-skyline-ti-burnout-car/
ok, I never even thought of the coyote, how do you think that would go with my engine bay though. would i have to change anything to be able to fit it in? Also how do you think it would go power to weight ratio??
Please excuse any "silly" questions, this is the first car i want to build myself :blush:
a mate of mine had a worked rb30E powered 31. went well for what it was, but a v8 would be better. know of another guy in town with a datsun stanza burnout car. pretty sure it has a natro sr20 in it. they start in 2nd gear and stay in 2nd gear. if the revs start to drop too much they give it a squirt of nitrous to pick the revs back up. you want torque for a burnout car so that you can get into the highest gear possible (the faster the tyres are going, the more smoke you'll get). this also means you can get plenty of smoke without having to keep it banging on the limiter, which helps with engine temps and engine life.
silly question.... rb30 E what does the E stand for? Also what KW did they get for that?
i like the sound of the coyote engine but also have to think of suspension n all that shiznit... im seriously leaning towards something of 5l or 5.7. If i go much bigger i think it will throw out my power to weight too much
:rolleyes: i am a sucker for Muscle though, coming from a family of mechanics
I want something to stand out from everything else. Hence why i dont want a turbo.
You want to stand out but you want to put a V8 in for something like Summernats...
Windsor 302...can get them dirt cheap, will be fine for the weight of the car, can get in carby or EFI configuration, relatively small engine, myriad of aftermarket parts available.
The E in RB30E stands for electronic fuel injection.
Ahhhh ok, thanks heaps. something to consider :thumbsup:
How much r we talking about?? or i had a suggestion for a LS1 and putting a manualised turbo behind it to get decent power to weight ratio?
any v8 conversion will cost a bit of money in fabrication (engine mounts, gearbox mount, custom tail shaft if needed) but will give you good results for a burnout car. a LS1 would be good since they are a light motor (lighter than the stock RB), and they are relatively cheap these days. hardly different though.
if you want to be different, try to squeeze a turbo 'BARRA' 6 engine (xr6 turbo engine) in there. might be a bit of a squeeze and will put a touch more weight over the front end, but they have a buttload of torque, are easy to make good power out of, and it will be pretty much one of a kind. just might not fit in with the v8 bogans at summernats as well as a v8 would though.
im putting a 357 in it .. getting quotes n shiz as we speak :rolleyes:
Cleveland, Windsor, SBC or Mopar?
I doubt a cleveland will fit without chopping the strut towers out, sames goes with a 351 windsor.
either way, big engine + little engine bay means epic overheat before 3mins is up.
Ever notice that all the engines that go pop due to overheating in burnout comps are those in little cars, eg toranas, cortinas, Rx4s etc
cleveland.
I'm not going short with this car. The engine for what i want will cost at least $40,000 if not more.
Plus the diff and tailshaft im getting will definately be able to handle the h/p that comes out of it.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
