Also for those that haven't heard the latest, there is a meeting planned for engineering signatories with the RTA (roads and traffic authority) next week.
There are around 70 engineers going to this meeting to discuss the proposed legislation on vehicle modifications, including the suspension regulations.
Basically they will be raising a lot of points about how silly some of the new proposed laws will be and try to explain why they are rubbish. Labor is backing the proposed laws, and the Liberals are against. Gives you something to think about voting time too...
Also they propose to raise the registration costs on older vehicles, to a point that the majority can't afford it, to get them off the road. That's under the Labor party.
Various things such as, vehicle owners, enthusiasts, the automotive aftermarket and workshops all come into play here as to whether we get to do what we enjoy and also the whole industry keeps going, or if we all end up driving white goods, with no soul, and not allowed to change anything.
That about sums it up, and that's just the start. If you guys have anything to add, please do!
Cheers
  • Like 1
Why don't you make a petition for not banning murdering and sent it to all the murderers while you're at it lol.
English? and WTF?
P.S. Signed
Edited by iplen
  • Like 1
Why does a road car need to be raised / lowered more than 5cm anyway? Track specials, I can understand, but anything that is road registered doesn't need to. If you're serious enough to have a car capable of winning championshios, then it will have a shedload of other illegal mods anyway, and most likely wouldn't be much fun on the roads.
Apart from possibly WRC cars, I haven't ever seen a rally car raised anywhere near 5cm, so that's no excuse (thinking about competition vehicles that *need* to be registered).
Maybe hardcore offroaders need the extra lift, and I'm not going to argue against that. Everyone else, OTOH, well I agree that 5cm is more than enough for a road car. Maybe it will get some of these dickhead slammed civics riding on 20" chromies off our roads.
Can't always have your cake and eat it too.
Edited by warps
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
