Thanks gents - chipping away at it slowly!
That is a nice tight fit. Looks awesome sitting in there though. I have a 31 sitting next my 32 at home will have to take some measurements the fullrace mani is absolute porn.
The mani is very nice but the finnishing in a few area's isn't to the standard I'd expect considering the asking price. Glad I got mine cheap!
Trial fit of the fuel cell all done, the hole saw packed it in so I had to resort to the slow method (lots of small holes followed by a file!). Good times :P
Cardboard is a template which will be made in steel to cover the old fuel tank access hole.
Edited by DCIEVE
^ thats something i need to do :)
had a look through your thread but i couldn’t see if you where planning on doing some circuit racing. if so, might the cell be in a bit of a dangerous spot or are you going to put some protection around it?
+ where did you get the diff mount from?
great build man :thumbsup:
Cheers James. Yeh the plan is club level stuff but keeping the rego while I don't have space for a trailer and dedicated tow car.
Not sure about the cell location being an issue, I can't really see any difference which side of the floor it sits on from a rear impact point of view (other than fuel spilling on the ground rather than inside the boot if it were to split). I certainly think it's better than mounting it part way through the floor like most people have to do due to the spare tyre well (risk of slicing it in half in a rear hit). It will be covered on the underside if that's what you mean?
Edited by DCIEVE
Brake master, clutch master & slave rebuilt plus some braided brake & clutch lines. Just need to give the booster a sand and coat of paint. Also grabbed some adjustable LCA's - I think originally godspeed but the welds have been ground back and professionally re-welded, they've also been machined to take off the shelf SKF bearings rather than the chinese bearings they came with.
Rebuilt both wastegates with new diaphragms/springs etc and set them up with shortened speedflow fittings (without cutting them down they limited valve travel).
Time to make some intercooler pipes and find someone to do the wastegate plumbing and new dump pipe.
Nice work Nick, got a rough ETA?
Hopefully in the first quarter next year but we will see. I still need to find someone to build the engine, and that's assuming the new head hasn't been lost in transit somewhere :(
  • 1 month later...
So I made good use of the long weekend, progress! But sadly still no head some 4 months later :angry:
Rebuilt brake & clutch masters fitted
Dummied up the flares
Lower rad hose adaptor for the rad breather tank from garage7.
Mocked up the new oil filter location
Found homes for the rad breather tank, accusump and fpr.... the accumulator is friggin enormous! Also fitted up the plenum so it's ready for IC piping to be made.
Getting closer! Shame it's not my engine :P
And put the seats back in so we can fabricate a hardness bar
Time for the fab work and hopefully some wiring.
From fatz stockpile of carbon bits ;)
The diff mount was from z31parts but it failed in fairly dramatic fashion so I wouldn't recommend one. It was replaced with a solid mount..which reminds me I need to find solid alloy subframe bushes to replace the nolathane ones which allow the subframe to move too much.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
