I bought a "Pro Lift" jack from Repco last week and was gonna buy their pin style stands as well but read this:
http://motamota.r31skylineclub.com/index.php?topic=143863.0
Can anyone recommend a trustworthy brand of stands so I don't die while working under the car? Are repco and SCA stuff usually crapola?
Cheers!
https://www.sau.com.au/forums/topic/352526-which-car-jack-and-stand/
I've got that jack, it's pretty nice. I have SCA pin style jack stands and haven't had any issues with them, they feel nice and sturdy.
I'm sure the poor bastards who had their pin style jack stands collapse thought they were nice and sturdy till the car dropped on them. There was a recall from Repco a while back for their home branded pin type jackstands, so personally I would rather put some rims or a lump of wood underneath rather than rely on a dodgy jack stand.
This has been posted last year > and about the death of that poor dude.
Repco also spruiks the use of a forklift type jack for low lip cars. This one is also dangerous, as its load bearing capacity is very poor.
First time I used them I kept the jack in place though not touching anything(as you should do anyway) and shook the car hard and it wouldn't move at all.
Its not so much about the stands falling over its about the pins snapping and the car dropping down like that poor fella who died underneath his 300ZX when that happend.
IMO Get the ones rated higher i.e the 2000kg jack rather then the 1000kg jacks. and if poserble a Australian standed sticker.
In saying that i have brought a few diffrent brands from diffrent places. like k-mart, autobarn and none have never bothered me.
actually it wasn't the pin style ones that had the recall, it was the ones with the ratchet setup where you just lift the lever and they would drop back down. the ratchet mechanism wasn't locking in properly.
AC Hydraulic jacks and stands. The JAck is a low profile one. long reach. high lift.
those stands are beefier than they look in the photos even.
Hey Just wondering where you got these ??
f**k me you guys should get a job in the mining industry.
"someone once got injured when a ratchet type chassis stand failed"
"Oh then we'd better ban all ratchet style chassis stands so it won't happen again"
pats on the back all round for making the world a safer place.
Paranoid much?
sorry havent been back here for a while.
got them from here:
Jonathan Gant
Jonair Services Pty Ltd
48 Cowie St,
North Geelong
VIC 3215 Australia
Phone (61) 3 52779932
Fax (61) 3 52779543
Mob (61) 418376064
you dont want to know the price of the Jack (ok about $900)
the stands were about $240 a pair. not cheap but most solid bit of gear I have seen.
$240 a pair is fine !
$900 for the Jack... well I'll eat more weetbix for that price.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
