I like those new wheels, I reckon they look good as they are but to match the Lenso's would look better with the red lip. What brake pads were you using?
EBC Greens were in there before, I wouldn't recommend them for anything more than a swiftly driven daily.
Hey Pete if you didn't already know its really easy to add a stripe to the wheels. You can either buy some red pin stripe or cut a pice out of vynal. It can just be a strait pice. As you put it on the wheel it will flex as such and turn a strait line into a curved line. So no need to paint it or cut out round stripes. I have done this neumerous times to wheels on a race car I used to look after.
Thanks Damo! I'll give that a go.
Yeah, I can vouch for EBC's not being suited to any sort of track use.
I had these on my daily driven Liberty, took it to the track, and cooked the pads, to the point where the backing plate that sits against the brake pistons were warped out of shape (not to mention caliper slide seals catching on fire, etc).
Nice wheels too, BTW.
  • 1 month later...
it might have to be white then.
Also, I think I need these.
http://www.ebay.com.au/itm/Nissan-Skyline-R33-GTR-GTS-Lambo-Vertical-scissor-doors-Direct-Bolt-kit-/220959735855?pt=AU_Car_Parts_Accessories&hash=item33723a002f#ht_2324wt_906
1. because the teenager in me that played waaaaaaaaay too much Need for Speed thinks they're hilariously awesome.
2. It'd make it possible to open the doors when it's on the trailer and I can get out of the car without bending like gumby!
Edited by zoidbergmerc
prolly should get a pair of these. 18x9.5 +22 for the front. purrrrrfect.
http://shop.cartel-aus.com/18-Varrstoen-221-Matte-Black-Alloy-Wheels-Var221MB.htm
Forgot to actaully post the link.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
