  • 4 weeks later...
That dash wouldn't be hard to replicate poit. I personally wouldn't give up my factory dash for that, but that's me. To make that in 1-1.6 mm ally sheet would be fairly easy, weekend job tops. Looks to be just satin black, few hole saw bits to match ur gauge sizes etc. looks NASCAR spec
Edited by Mr. Untouchable
yeah I think I should just tidy up my stock dash and leave it, take the heater core and AC out too, seeing as they're not hooked up...
I need to make some door cards more than anything!
Edited by zoidbergmerc
  • 3 weeks later...
I've been fooling around with the 33 and took some pics to share.
So I thought I had a pretty major problem when at symmons plains I was getting some SERIOUSLY bad vibe through the wheel\car when going faster than 90kph. I was like the f**k my car is going to fall apart.
I was pretty convinced that something was seriously a miss with the passenger side front suspension\bearings, something was not right. I pulled it all down and low to behold, it was all brand new, it wasn't till I was putting the wheel back on that I discovered the massive flat spot on the tyre -_- FAIL
Then I painted and fitted my new wheels, they're Rays SS7 18x9.5 +38 but to get them to fit I had to install a 15mm bolt on spacer as they fouled on the upper wishbone(?) when on full lock now it clears by about 1mm. They were gold but now they're Matte black, and I'm thinking of painting the lip red to match my lensos and break it up a little. The tyres are Dunlop D03Gs in a medium Compound, 245\40\18 for the front and 265\35\18 on the back.
I'm pretty sad about my Drift Teks getting so f**ked up after my little spill at Symmons :( Those rocks hurt!!
I also put in a passenger seat for the Charity Rides day in a few weeks :)
I also fitted some new brake pads, Hawk DTC-60 should pull the while whale up nicely :)
Hey Pete if you didn't already know its really easy to add a stripe to the wheels. You can either buy some red pin stripe or cut a pice out of vynal. It can just be a strait pice. As you put it on the wheel it will flex as such and turn a strait line into a curved line. So no need to paint it or cut out round stripes. I have done this neumerous times to wheels on a race car I used to look after.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
