Ok so this is not an extreme build or anything flash but might be interesting to some of you out there.
with the R35 being relegated to track only use I needed a tow car, so I sent about purchasing a suitable vehicle, swell sort of suitable....
I ended up with a 1999 GU Ti Patrol with the 4.5L petrol engine. Diesels are not that easy to find, certainly not as tidy as this car ast least.
14,000km on the clock, mint as. Dont belive me? Come see it at QR sometime lol.
The purpose of the build is to take the asthmatic 4.5L petorl engine somewhere closer to being good for towing.
introducing the underpowered whale....
who would have thought 4.5 litres would get you so little mumbo
https://www.sau.com.au/forums/topic/353472-99-gu-patrol-tow-car-build/
Firt up, a few interior mods.
Install done extremely well by the guys at Northfield at Mooroka
Looks OEM
Alpine IVA-W520BTi with NVE-M300P Package. This is Alpine's premium in-dash unit with the Bluetooth and Navigation.
Alpine TMX-R1100E. 10.2" roofmount screen with High Definition display with cordless headphones.
3950-patrol004.jpg __________________
Exhaust manifold being fabricated, it is now finished and off for sandblasting/coating
new goodies have arrived - intercooler and new power steering cooler (needed to be shifted)
Luke at Mercury is fitting all the piping up today.
really nice gu you picked up there mate, please get a tranny cooler put in too, auto's in forby's get hot with lots of beach work and towing etc and with you chucking a turbo on it as well it's going to be working hard!
the motors are also designed with low down torque in mind, they might not go so hard 'for 4.5' litres on road, but when your climbing a hill with the revs at 1100rpm and it keeps on pulling you realise how they work.
also you might want to look at a set of stronger rods, the tb45 ones aren't known to last long with boost in them, tb42 rods are a fair bit stronger and cheap too
plenty of info on outer limits forums if your interested
keep us updated
^^agreed and maybe a transgo shift kit or alike
also post on this big fella http://www.nissanpatrol.com.au/forums/forum.php
just make sure you introduce yourself first....they don't like it much if you start posting away with no intro.
nice idea. I am a bit shocked at the kms though. who the hell does an average of 1,250kms a year over 11years? Most Ferrari and lambos do double that or more! is it the worlds first collectible patrol?? lol.
hopefully the big boy will get some decent torque with the turbo to pull the 35 and trailer as they are a fair bit of weight. :)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
