Got heaps of random shit thats in the way
R33 Dash cluster 50 odd thou km, told the tacho was a lil dodgy but you can mix n match whatever guages you need $60
R31 Dash cluster 153,000km $50
R31 Auto tail shaft $30
R31 Auto trans perfect working condition. $50
Heaps of rb30 parts like throttle position sensors, coils, dissy's, afm's $10 each
R33 Boot lid, White, Lock has been shaved off, needs respray $50
GReedy turbo timer, old school one $30
pair s15 stockies with f**ked tires $60
It's all in the way, come and get it
can deliver if required 0405322061
Edited by Ryanrb25
FOR SALE - R33 GTST Drivers Side Door Interior
I have the door interior for the drivers side in excellent condition and need it out of my unit, i have no room for it.
$25 come and take it off my hands.
Mobile: 0413790035
got 6 rb20 coil packs for sale in good condition $100ea
pm or contact me on 0432 075 410
so 6 coilpacks = $600
mate you can get some brand new splitfires for around the 450-500$ mark
i am guessing its just a typo :P
P1 Buddy Club Rims. 16x7.5 (+32 offset) all round!
Bought these to use as track rims but they don't clear the brembo's and i don't want to use spacers.
they are in extremely good condition.
pretty good offsets for a street car with a 16" rim.
I have a full set of semi slicks too that can be included for the right price, they have been used quite a bit but will still have a few track days left in them, from memory they are advan a408's???
$500 for the rims with no tires.
$200 for the slicks.
$650 for the lot.
Cheers, Ash!
0413045900
For Sale - R33 400R Front Bar
i bought this and was going to fix it and place on my 33 but found the gtr style bar and put that on instead.
this 400r has a crack in the fibreglass as you can see in the pic, nothing more fibreglass cant fix.
got told it came off a s2 33 but im guessing it will fit both s1 and 2.
looking around $150ono PM if interested
$650 for the lot.
Cheers, Ash!
0413045900
Selling the missus car.
Cheap car to run.
Suzuki Swift.
Twin cam, fuel injected.
212,000kms.
5 speed manual.
3 months rego.
Almost brand new tires.
Pioneer head unit and speakers.
Straight and runs well but the green paint is far from perfect. (badly faded on the roof)
$1500
0413045900
R32 GTR WHEELS
repainted in gunmetal grey and bronze, look different colours in different lights! purple bronze grey etc.
specs 16*8s all round, have front around 80% tread rears 70%, only been on the road for 3 months!
saw a set of gtr wheels go for $600 the other week, which were just grey, so ill put these up for $650!
obviously they sit wicked on gtst r32 with no guard rolling camber e.t.c needed! looking for a quick sale as the skyline is begging for new shoes!
reason: time for a change, otherwise would keep them!
tyres: tread value above, brand are falken all round!
pm me or sms anytime 0431 308 333
ta jonny
buy me please need some new shoes
Edited by Jonnyboy89
$500 for the rims with no tires. SOLD!!!
Cheers, Ash!
0413045900
rims sold, semi's still available!
Forsale R32 GTR front parts all black and in good condish (will fit GTST)
-2x guards GTR -$400 both
-Front bar GTR (sold)
-Grill GTR -$100
-RAD Surport GTR -$200
-Bonnet GTR -$300
SA pick up
contact -Alex 0421340064
For sale:
2 x 275/40/17 Nitto NT555R Drag Radials - see attached picture for % of tread life remaining.
$100
Genuine TRUST muffler, polished, 76mm inlet, 100+mm outlet, excellent condition.
$90 - SOLD
Exhaust housing and wheel: Black ceramic coated Turbonetics T3 5 bolt internal gate (same 5 bolt pattern as Garrett internal) Stage 5 0.63A/R exhaust housing and Big Shaft exhaust wheel. Both near new (20km/h road use - handful of dyno runs). Also comes with internal gate flange - not pictured. Can supply part numbers and exact spec's for genuine buyers. Will support well over 300rwkw and would be excellent on a 3.0L
Just purchased Stage 3 of the above and paid $790.
$180
Locally made (not a Chinese import) R33 front mount intercooler 600mm x 300mm x just under 60mm. Good condition.
$90
Set of 6 Series 1 RB25DET coil packs. Never missed a beat and simply upgraded them with Splitfires because I wanted to.
$60 for the whole set
Genuine Nismo horn button, still in Nismo parts bag, never fitted - does not fit Momo 'Race' s/wheel.
Can supply photo on request - once I've taken one.
$25
Last, but not least, set of 6 x 550cc injectors - Mazda OEM top feed. Ultrasonic cleaning peformed on them, have supported over 300rwkw on Boostworx dyno as fitted to my RB25DET. Currently still fitted, but will be removed and available as of approx' 17th Nov 08.
$340
Contact via PM, Phone: 08 83933174, or SMS on 0414 865 784
For sale:
PM sent
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
