H3 8000k HID Xenons$175
Rb26 pod set up
2x drift pods, 2 mountig brackets, adapter plates and a 90 degree bend. was in the 260. $50
S1 Stagea N/A Grille $100
S2 Tail lights $450
Work VX-SS 17" Rims $2200
17x9.5+24 (front) 17x10+22 (rears) they clear brembos
Stock S1 260 RS Stagea. silver etc etc etc $23500 pm me or see car sales for details.
Edited by chef_stagea
Wont be needing these stuff anymore!
Boost Controller, Greddy Profec B Spec 2 comes with all wires and plugs ;$400.00
Boost gauge, Greddy Defi Mount (suits R33) + Apexi 60mm Boost gauge ;$200.00
PM me, and please no time wasters wont be putting the price any lower.
have posted this on NS.com aswell!
Selling it already Ruby?
Going from AWD to RWD is not my thing. I'm going to get myself into trouble :down:
Jokes ... Tracy has her car back repaired and all (she hit a f**king big dog not long ago) and she loves the 33, but the Liana is more practical for her ... and better on fuel. Its also 60,000kms compared to 130,000kms, and it looks brand new again. Sure it doesn't have an RB, but there are many other features that win. She bought the Liana and built her house as a single mom many moons ago. Now the house is sold and she just can't make herself sell the Liana ... there's a bit of sentimental value. Its either the Liana or the 33, so the 33 will be the first to go.
He cannot handle the awesomeness of the 33 James
Tracy cannot handle its awesomeness. :bunny: I may just still keep the car for a daily ... well, it is going to be my daily until someone buys it ... but I'm in no hurry. Just putting it out there :)
Plus some of the money would be good to set up my race bike, which I just bought back (picking up next week). Getting back into racing next season (haven't even done a track day since I sold my 600). Haven't raced since I broke my shoulder in Feb 2008 ... so I got a big itch to scratch. ;)
Blitz 550cc injectors (x4) suit SR20.
good condition.
require different harness plugs, petroject stock them for a few bucks each.
$400. not negotiable.
gktech s/steel bell mouth dump pipe suit s13/4/5 sr.
as new condition, never used.
$80. slightly negotiable.
(image from gktech)
gktech alloy sump guard to suit s14.
used, little dirty, but in great condition.
(image from gktech)
contact me through here or on 0408961657.
cheers,
dave.
dump pipe sold.
1995 r33 series 1 SKYLINE SLEEPER
WINE RED (HAS MORE METALLIC AND IS A DEEPER RED)
FORGED ENGINE
REBUILT GEARBOX
R33 GTR RIMS WITH 235/45 TYRES FRONT AND BACK
FULL BRAKE UPGRADE INCLUDING DBA SLOTTED FRONT N BACK ROTORS
MOST PARTS ARE NEAR NEW
I HAVE ALL RECEIPTS TO SHOW HOW MUCH I HAVE SPENT ON THE CAR OR YOU CAN RING SIMON AT MORPOWA FOR CAR HISTORY
WILL POST FULL SPECS AND PICS SOON
$21,500 ONO
DANAI 0402541975
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
