Anyone interested in any PS3 games?
I have Red Dead Redemption, COD4, Fifa10' - my ps3 shit its pants, not sure I can be f**ked repairing it.
$60 a game or gtfo. Will do all 3 for $150.
dont even, you can certainly be f**ked repairing it. Its a PS3, think how much you miss her. If you definately cant, then ill trade you Fifa10 for a green ham sandwich and a pint of dwarven ale.
For Sale
1/ Holden 253/308 heavy duty clutch never used suits M20 $150
http://i533.photobucket.com/albums/ee334/r...ds/P1050372.jpg
3/ R33 series 2 turbo very minimal shaft play, was running 12psi for a while comes with stainless dump and 3" stainless pipe to cat. Taken off car 3 months ago no problems. $400
http://i533.photobucket.com/albums/ee334/r...ds/P1050370.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050369.jpg
5/ R33 NA rear brake calipers and discs good condition $30
You can PM me or ring Brad on 0427999093
Bump
Still for sale
Turbo is now $500 because I found out its an r34 with OP6 housing. Pity it wasnt snaped up earlier. I wouldnt of known.
Hi there all,
I have the following parts available for sale from my silver series 2 gtst coup:
Right Hand Drivers Door Complete..
front pair of seats and rear
wiring loom
boot trim
carpet
complete interior
genuine factory sunroof
rear bumper
GTR spoiler
RH side skirt
steering rack complete
steering column inc keylock and key
3 point black immobiliser with remote windows and roof
Greddy front strut brace (new in box)
ABS brake controller
Clutch master cylinder
HR33 spare tyre (new)
dash and surround all inclusive
HICAS diff
and more
please call 0449326440 or PM me
Prices and photos will be posted soon
how much for Clutch master cylinder ??? is it for a 32 ?? or do u know if it will fit
Bump
Still for sale
Turbo sold pending payment thanks
basically if this stuff doesnt sell by sat 3pm then its not for sale anymore, need the money so make an offer, but nothing stupid
NO TRADES FOR f**k SAKE EITHER
Sard oil pressure, water temp and oil temp guages
all sensors, except for oil temp sensor (should be able to hook onto something to get the signal though)
all wiring
$500 or offer
Bosch 040 Fuel Pump
done sweet f**k all kms
$150 FIRM
Greddy Boost Gauge
black face
lights up green
$180 ono
Silk Road R32 GTR vented headlight
actually makes a difference to performance
$250 FIRM
JIC FLT R32 GTST coilovers
no knocks, leaks, noises, cracks
$1000
R32 GTR N1 Headlights
no cracks, all bolt brackets in tact
$400
235 45 17 NEUTONS
brand new, stickers still on
$180 FIRM, thats what i paid for them
sms or call me on 0458 667 748
located in adelaide, will post all the stuff, but only if the cash is deposited and in my hands by saturday
I can bring the gauges or headlight or fuel pump to melb on sat if you want aswell
pictures up in a few mins
Gates timing belt kit for RB
braught a dayco belt and didnt know it was already done on my car.
found the sticker under the cam cover... the kit was used for 6,734 Kms and is in new condition... NO marks, ware etc...
the idler pulley and tensioner spin exactly like the kit i put in...
i got half way n had to keep going. inspection welcome...
comes with
1x belt
1xtensioner
1xidler pulley
the dayco oil seals that came from my kit... great for someone who to do theres soon...
$50
will it fit RB20 ???
3inch resonator,purchased Monday and fitted taken off and replaced Wednesday with a bigger one
5inches round,I think 12inches long
reason for removing was it was way too loud with the new straight pipes and I thought it would quite it down enough,but it didn't
$80 bucks pick up from Marion or magill
Rotors 280mm x 28mm vented rotors
$75
Calipers to suit ... from series 2 Stagea (14mm bolts)
$75
Swap R33 GTST rotors for R34 GTT rotors, or GTR 324mm rotors, plus small cash difference?
I have decided to go down a different path and my R34 Power FC for the Neo engine is for sale.
Never been installed in my can and bought it off a person that had only had it in there car for 1 month.
It is $1200 Firm as i paid alot more than this for and they are genuinely hard to find.
PM if you are interested
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
