mums daily car,
she doesnt need it anymore wants me to get rid of it.
91 KF laser, white, manual, 1.6L carby, think its just under 200,000kms or maybe just over. Runs fine, new cv joints, new brake pads, water pump/timing belt done less then 3 months ago. comes with 15" alloys, however one tyre is bust and is on a stocky. very very cheap on fuel. Battery less then a year old. Bit of paint missing on rear bumper but its cheap!!! Rego runs out soon.
$1,200ono.
pm me
or 0422 314 938 (Marko)
TRD sticker can be negotiated with the purchase :P
Can get pics on request but come and see it in person, take it for a test drive or whatever!!!
Item:
RB26- R32/33/34 complete oil cooler kit for sale with stainless hoses , filter holder + brackets
18 row cooler , complete with all adaptor fittings was $400 new
Item condition:
:P New
Contact details:
Please pm
Price:
$220 - or Reasonable offers !!!!!
Pics:
Drift special tyres, still lots of legal tread ??
235/40/18 x 2 Firenza ST08
some inner wear but not on the wear bars yet.
you pick them up from down south, $ 40 for the pair
PM... first one gets em.
wrecking s1 r33 in silver im keeping these parts but everything else for sale, the car has rear end damage
KEEPING: gearbox, front brakes,tail shaft,steering rack,front lower control arms,
THE ENGINE IS A SERIES 2 complete engine, loom,ecu
completely stock, never even been boosted.
still in the car so can hear running, compression and any other tests welcome....$1800 $1600
OTHER PARTS:
bonnet $100
S1 front bar $80
lh guard with indicator $100 each $80
s1 headlight $80 each
rh complete door $150 each
s2 spoiler $50
rh mirror $30 each
type m sides fiber glass $100 $80 needs bit a work
fuel flap $10
rear window $100 taken out
quarter glass $80
radiator $100
condenser $50
condenser fan $50
master cylinder non abs $80
washer bottle $20
cluster $100
dash $100
mint air bag steering wheel with clock spring $140
seats $100 pair
glove box $20
console $40
door trims and 1/4 panel trims $40 each
seat belts $20 each mint
indicator and wiper stalk $25
rear seats $40
manaul conversion pedals clutch master interior boot trim $150
anything else just ask, will swap for parts of interest!
LOCATED IN ATHOL PARK...TEXT or CALL on 0422030855
Edited by hcR324door
mums daily car,
$1,200ono.
pm me
TRD sticker can be negotiated with the purchase :bunny:
SOLD
S14 front 4 pot calipers + rotors $220
includes pins, shims, stock lines, good Bendix pads, slotted RDA rotors
Broken S14 SR20DET gearbox, 160,000kms old $60
Blown second gear, good for cut and shut bellhousing or rebuild
Factory S14 SR20DET sump $make an offer
Taken out of car to upgrade to bigger baffled unit
Whiteline eccentric camber adjustment bolts KCA414 $50
Adjust camber on the front struts, 14mm bolt, suits S14 and lots of others
180SX factory quarter window visor thingos $make an offer
a few clips broken when removed from car
R32 handbrake cables $20
Stock S14 swaybars $30
Can provide photos on request. Prices somewhat negotiable.
Located north eastern suburbs SA. PM or SMS 0424085308.
Still got 2 sets of suspension to sell
$600 for Bilstein R32 GTR/GTS4 - provides a nice balance between street and track performance, but is not street legal due to eyebrow height
$500 for Tein HR R32 GTR/GTS4 - stiffer than the bilsteins, so more oriented to track use, however these actually ride higher and are street legal
and I can still source injectors for those who want it. Windowshoppers and shoegazers can get f**ked. PM me only if u want to buy, I dont tolerate time wasters
-D
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
