FS- 32gb BLACK iphone 4
comes with ALL packaging. its mint, never been without protective screen and cases, have multiple cases to go with.
its jailbroken atm with heaps of apps, but can reformat it if you want.
want $600firm.
cheers guys!
sold and collected
Putting my car back to stock, various items For Sale
All items 12 months old and used for 20,000 km
R34 GTR Power FC with hand controller (Tuned with Nismo airflowmeters, 800cc injectors, 98PULP, 16psi, 280kw) $600
R34 GTR White 320km Dash 20,919km (In original box) $400
Splitfire Coil Packs P/N DIS-005 (R34 GTR, R33 Series 2) $250
Blitz Dual-SBC Spec-R Boost controller Kit $300
Nismo Low opening thermostat P/N 21200-RS580 (RB engines) inoriginal box $40
Innovate LC-1 with XD-16 Digital wide band O2 sensor Kit(Has original box with spare faces, instructions, exhaust bung, etc) $120
All items ready for pick up in Adelaide
All items can be posted at buyer expense
Photos available via email just PM me for them
Call me on 0401 469 148
SWAP: I have 6x Nismo 555cc yellow top injectors (side feed drop in) wanting to swap for some 850cc injectors (want to setup for e85 tune) don't mind if they're top feed as I have a Greddy plenum, prefer 4 hole spray.
Will sell outright for $550 in STD fuel rail. Only installed for a couple of months and done 1000kms
Make: Nissan
Model: R33 GTS-T
Transmission: Manual
Colour: Black
Currently registered? Yes till 18/8/11
Price: $9,800 (or will swap for a car of lesser value + money my way, or less without wheels)
Contact: 0402 902 759
Comments / Modifications:
Engine fully rebuilt and balanced with CP forged pistons, rings, new bearings, gaskets as well as rebuilt head and comes with all receipts for engine work. Combined with FMIC, Bosch fuel pump, exhaust, Exedy clutch and Apexi coilovers, makes for a good all-round package.Also comes with a VIPER 2 way paging alarm.
Compression tested - Between 179-176psi for all cylinders, an extremely good result.
ENGINE
- Full engine rebuild with CP forged pistons + rings, fully balanced with all new bearings and gaskets.(Comes with $10,000 Worth of receipts for engine + clutch)
- Rebuilt head
- Exedy Super Single Brass button Clutch
- Bosch 040 Fuel Pump
- Turbosmart boost controller
- Front Mount Intercooler
- 3A Racing pod filter
- 3" front and dump into a 3" cat and 3" cat back.
SUSPENSION
- Apexi N1 Coilovers
- Endless hicas lock bar (Engineered with paperwork from Doug Potts & and passed through Regency)
- Replaced Diff with 4.11 Ratio
INTERIOR
- Re-trimmed Leather Steering wheel, Perfect condition
- Silver Dash Surround
EXTERIOR
- S2 rear wing
- Standard S1 M Spec Front Bumper (average condition, Has a crack in the front)
- Jun rear bar ext
- DNA Wheels. 17x9 +30 all round
- GTR type grill
- nismo indicators
Bad Points:
Could do with a polish as its been stored in the shed for 6 months
R34 GTR Power FC with hand controller (Tuned with Nismo airflowmeters, 800cc injectors, 98PULP, 16psi, 280kw) $600 Sold
Splitfire Coil Packs P/N DIS-005 (R34 GTR, R33 Series 2) $250 Deposit Taken
Nismo Low opening thermostat P/N 21200-RS580 (RB engines) inoriginal box $40 Sold
Hey guys I have a set of stock R32 gtst rims with 225s, rear tyres are near new and fronts about 50%. The rims aren't in particulaly good condition. Will take pics on request.
Will take $50 for them, want to free up space.
Edited by Absent
PM'd
What size are the tyres?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
