- r33 gtst Rubber intake pipe with oil breather apparatus $35
- r33 gtst Stock dump pipe $20
- r33 gtst Stock dump & front pipe $30
- r33 gtst Oxygen sensor $40
- r33 gtst Air Con fan $35
- r33 gtst Stock Intercooler + Pipes $65
- r33 gtst Series 2 coil pack loom $40
- r33 gtst Alternator $60
- r33 gtst 2nd hand water pump works fine $35
- r33 gtst Timing belt $30
- r33 gtst Bosch Air con, power steering, alternator belts brand new $70
- Garrett Adjustable Actuator with bracket 15psi ( New) $70
post-31991-0-00191800-1312509850_thumb.jpgpost-31991-0-47424700-1312510002_thumb.jpgpost-31991-0-65943700-1312510039_thumb.jpgpost-31991-0-40924900-1312510062_thumb.jpgpost-31991-0-23302700-1312510069_thumb.jpgpost-31991-0-69927800-1312510096_thumb.jpgpost-31991-0-38416300-1312510119_thumb.jpg
EOI: 17x9(i think, might be 8's) Drift R rims, 5x114.3 full set, near new tyres on rear and ok condition tyres on front. Slight gutter rash, good condition otheriwse. $800 ono.
R33 plazmaman intake plenum.
Comes with plenum, bottom half to head, vacume fittings. All you need is to bolt your throttle body onto it and your idle control valve.
$950
Rb25 hiflow 740cc injectors. Run 380rwkw
Come with rail
$450
$950
Come with rail
$450
OK... is there a adjusted price if both are taken and if you have flow results for the injectors and have they have been run together(plenum+rail+injectors)? Plus receipts for the plenum, etc? Basically a EOI from me ATM.(no guarantee's)
(looking to change my setup soon and these kind of things will be needed, post pics if you have them)
Cheers,
Shannon
Hey Shannon.
Can arrange a package.
I'm in Sydney atm so no pics.
I don't have the reciept but I bought the manifold new and its painted black.
The injectors I got hiflowed from a member on here. The have been flowing good numbers for a year now.
Txt me. 0433290801
For Sale.
Set of excellent condition G4 Racing coilovers for R33 GTR, anodised blue in colour, bought these for my z32 as was told that they would fit, rears dont so there up for sale
chasing $700 firm
also comes with 2 Laser cut 5mm steel C-spanners i had made at work.
PM or Sms on 0424521315.
pics via sms
Bump.
180SX
L&RH DOOR LATCH INSERTS $ 15
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32 CLUTCH SLAVE
R33 STEARING COLLUM
PLz pm offer on anything u need dont have time to go throught it all and find out what its worth
cheers
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $10ono
2: HKS Boost guage and loom (60mm) $40ono
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $40ono
4: 2x 5 stud 15mm Hubcentric Bolt On Spacers $100 FIRM - Need to sell spacers ASAP
5: R32 2door L&R boot trim $5 each (Has holes cut out for strut brace)
Or take Boost guage and piller for $50.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
Few parts bits and pieces:
RB25 POWER FC, with hand controller: $1150
LEFT TO RIGHT:
R32 $120
R34 $250
R32 $120
S13/180sx $120
R32 $120
JUN Front bumper $100
JUN Sideskirts $100
are those side skirts for the R34 GTT?
fs
r31 silouette shell roling wired for rb25det
front coilovers
rear is aftermarket shocks and springs very stiff
boost and temp guage sparco
new 2.5 " exaust system
s13 lcas
s13 knuckles
Garage 7 tie rod ends
Lock spacers
huge front sway bar
all bushes been replaed withn noalthane
all lights work
sr20det front brakes
new pads and rotors allround calipers rebuilt
freshly shimmed diff comes wit spare wellded centre and axels
no plates track only.
built for missus she slid once at drift school did great job i have also slid this car and handled awesome very easy to steer very good car for a grass roots drifter had no troubles with it
1800 ono only missing engine and trans sold on 31 silouete stockys
Thrust bearing to suit pull type clutch for GT-R
Bought it the other day from Just Jap, only to realize I had one supplied with my replacement clutch..
$50 if someone wants it, I can bring to dyno day this weekend if not I'll use it for my next clutch haha
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
